[petsc-users] MATELEMENTAL
Jin, Shuangshuang Shuangshuang.Jin at pnnl.gov
Tue Jun 11 15:22:04 CDT 2013
Hello, I'm trying to set my Jacobian matrix to MATELEMENTAL type.
According to an Elemental matrix example code: /src/mat/examples/tests/ex38.c, I wrote my piece of code as following:
  ierr = MatCreate(PETSC_COMM_WORLD, &J); CHKERRQ(ierr); // J: Jacobian matrix
  ierr = MatSetSizes(J, 12, 12, PETSC_DECIDE, PETSC_DECIDE); CHKERRQ(ierr);
  ierr = MatSetType(J, MATELEMENTAL); CHKERRQ(ierr);
  ierr = MatSetFromOptions(J); CHKERRQ(ierr);
  ierr = MatSetUp(J); CHKERRQ(ierr);
  PetscInt       nrows,ncols;
  const PetscInt *rows,*cols;
  IS             isrows,iscols;
  PetscScalar    *v;
  ierr = MatGetOwnershipIS(J, &isrows, &iscols); CHKERRQ(ierr);
  // Set local matrix entries
  ierr = ISGetLocalSize(isrows, &nrows); CHKERRQ(ierr);
  ierr = ISGetIndices(isrows, &rows); CHKERRQ(ierr);
  ierr = ISGetLocalSize(iscols, &ncols); CHKERRQ(ierr);
  ierr = ISGetIndices(iscols, &cols); CHKERRQ(ierr);
  ierr = PetscMalloc(nrows*ncols*sizeof(*v), &v); CHKERRQ(ierr);
  printf("nrows=%d, ncols=%d\n",nrows,ncols);
  for (i = 0; i < nrows; i++) {
    for (j = 0; j < ncols; j++) {
      v[i*ncols+j] = jacVal[i][j]; // jacVal stores the value of the 12*12 Jacobian matrix
  ierr = MatSetValues(J, nrows, rows, ncols, cols, v, INSERT_VALUES); CHKERRQ(ierr);
  ierr = ISRestoreIndices(isrows, &rows); CHKERRQ(ierr);
  ierr = ISRestoreIndices(iscols, &cols); CHKERRQ(ierr);
  ierr = MatAssemblyBegin(J, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
  ierr = MatAssemblyEnd(J, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
  ierr = ISDestroy(&isrows); CHKERRQ(ierr);
  ierr = ISDestroy(&iscols); CHKERRQ(ierr);
This works for one processor. When it goes to multiple processor, it will fail.
I notice that when the # of processor equals to 1, the nrows and ncols will be 12 each, which are the dimension of the Jacobian matrix.
However, when the # of processor goes up, for example, to 2, nrows=24, ncols=12, then it will fail because the index of my jac[i][j] are withn [0, 11].
My question is, to use MATELEMENTAL, what is the rule to fit the values of my 12x12 matrix into a 24X12 arrays by the two level for loops?
And I don't understand what the set means here:
[d3m956 at olympus tests]$ mpiexec -n 1 ex38 -Cexp_view_ownership 1 -m 12 -n 12
Ownership of explicit C:
Row index set:
Number of indices in set 12
0 0
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
10 10
11 11
Column index set:
0 0
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
10 10
11 11
nrows=12, ncols=12
[d3m956 at olympus tests]$ mpiexec -n 2 ex38 -Cexp_view_ownership 1 -m 12 -n 12
Row index set:
[0] Number of indices in set 24
[0] 0 0
[0] 1 12
[0] 2 1
[0] 3 13
[0] 4 2
[0] 5 14
[0] 6 3
[0] 7 15
[0] 8 4
[0] 9 16
[0] 10 5
[0] 11 17
[0] 12 6
[0] 13 18
[0] 14 7
[0] 15 19
[0] 16 8
[0] 17 20
[0] 18 9
[0] 19 21
[0] 20 10
[0] 21 22
[0] 22 11
[0] 23 23
nrows=24, ncols=12
[1] Number of indices in set 24
[1] 0 0
[1] 1 12
[1] 2 1
[1] 3 13
[1] 4 2
[1] 5 14
[1] 6 3
[1] 7 15
[1] 8 4
[1] 9 16
[1] 10 5
[1] 11 17
[1] 12 6
[1] 13 18
[1] 14 7
[1] 15 19
[1] 16 8
[1] 17 20
[1] 18 9
[1] 19 21
[1] 20 10
[1] 21 22
[1] 22 11
[1] 23 23
Column index set:
[0] Number of indices in set 12
[0] 0 0
[0] 1 1
[0] 2 2
[0] 3 3
[0] 4 4
[0] 5 5
[0] 6 6
[0] 7 7
[0] 8 8
[0] 9 9
[0] 10 10
[0] 11 11
[1] Number of indices in set 12
[1] 0 12
[1] 1 13
[1] 2 14
[1] 3 15
[1] 4 16
[1] 5 17
[1] 6 18
[1] 7 19
[1] 8 20
[1] 9 21
[1] 10 22
[1] 11 23
nrows=24, ncols=12
Shuangshuang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130611/924b94fb/attachment.html>
