[petsc-users] error while allocating dense distributed matrix
Thu Jun 6 18:30:36 CDT 2013
  The first "num_cols" argument refers to the number of "local" columns on that process the second one the total number of columns. With size > 1 they cannot be equal. The sum of all the "local" columns across all processes must equal the total number of columns.
This is not explained well in the MatCreateDense manual page, sorry. Look at the manual page http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateAIJ.html and see the definition of m and n which explains it much better. The "local" row and column sizes are define by the "left" and "right" parallel vector layouts for vectors compatible with the matrix.
   Barry
On Jun 6, 2013, at 4:55 PM, Michael Povolotskyi <mpovolot at purdue.edu> wrote:
> Dear Petsc developers,
> petsc gives error with the error code equal to 60 when I'm doing the following:
> ierr = MatCreateMPIDense(comm, m, num_cols ,num_rows,num_cols,data,petsc_matrix)
> on rank = 0 the gebugger gives:
> (gdb) print m
> $1 = 240
> (gdb) print num_cols
> $2 = 18
> (gdb) print num_rows
> $3 = 360
> on rank = 1 the gebugger gives:
> ierr = MatCreateMPIDense(comm, m, num_cols ,num_rows,num_cols,data,petsc_matrix);
> (gdb) print m
> $1 = 120
> $2 = 18
> $3 = 360
> (gdb)
> Could you, please, tell me what is wrong here?
> Thank you,
> Michael.
