[petsc-users] Basic question on making SNES continue its iterations
Wed Jun 5 12:04:56 CDT 2013
On Wed, Jun 5, 2013 at 12:33 PM, Gaurish Telang <gaurish108 at gmail.com>wrote:
> I am trying to solve a non-linear system with PETSs's SNES solvers.
> To run my code, I am using the following options for snes set through the
> command-line,
> seen below.
> mpirun -np 1 ./Testvector \
> -fBus      $1/Bus.mat \
> -fYm       $1/Ym.mat \
>  -ft       $1/t.mat \
> -flinedata $1/linedata.mat \
> -nox \
> -snes_atol 1.e-5\
> -snes_stol 1.e-6 \
> -snes_rtol 1.e-12 \
> -snes_max_it 100 \
> -snes_max_linear_solve_fail 100  \
> -snes_converged_reason \
> -ksp_type preonly \
> -pc_type lu \
> -pc_factor_mat_solver_package superlu_dist \
> -snes_monitor \
> > result_superLU_dist.tmp 2>&1;
> After feeding my data, I get the following output
>  0 SNES Function norm 2.438306296478e+02
>   1 SNES Function norm 1.679437793666e+02
>   2 SNES Function norm 1.493618467597e+02
>   3 SNES Function norm 4.622194635741e+01
>   4 SNES Function norm 4.195017632984e+01
> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 4
> As you can see the the SNES function norm is *decreasing*, which indicates
> it is probably converging slowly to the actual solution. However after just
> 4 iterations, it stops and indicates non-convergence, even though my
> -snes_max_it = 100 as shown above.
> Is there a way to tell PETSc to continue its SNES iterations? Maybe some
> there are some
> default parameters which have to be changed?
You can try -snes_max_fail <num> or maybe -snes_linesearch_type basic.
  Matt
> Thank you
> Gaurish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130605/2646194d/attachment.html>
