[petsc-users] a question about DAE Function
Tue Jun 4 18:27:35 CDT 2013
"Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> Sorry about the confusion. Please allow me to illustrate the problem in a better way below:
> I have a set of DAE equations, which can be defined as 4*n f[] equations:
> As you may see, all the f functions are dependent on some x
> values. However, the x is a distributed array of size 4*n.
Thanks, this problem is dense.
> In order to use the access x[] from different processor, I have to
> scatter x before I use them to define f[], the scatterMyVec function
> is shown below.
> // Scatter the context of v to each processor to get a global array (vArray) values
> static PetscErrorCode scatterMyVec(Vec vin, PetscScalar **voutArray)
>   PetscErrorCode ierr;
>   VecScatter ctx;
>   Vec vout;
>   ierr = VecScatterCreateToAll(vin, &ctx, &vout); CHKERRQ(ierr);
>   ierr = VecScatterBegin(ctx, vin, vout, INSERT_VALUES, SCATTER_FORWARD); CHKERRQ(ierr);
>   ierr = VecScatterEnd(ctx, vin, vout, INSERT_VALUES, SCATTER_FORWARD); CHKERRQ(ierr);
>   ierr = VecGetArray(vout, voutArray); CHKERRQ(ierr);
>   ierr = VecScatterDestroy(&ctx); CHKERRQ(ierr);
Note that you can reuse the VecScatter.
>   ierr = VecRestoreArray(vout, PETSC_NULL);
Please don't abuse VecRestoreArray to lie to PETSc.  Yes, it will "work"
with normal PETSc Vecs, but not in general (e.g. GPU-backed Vecs).
>   PetscFunctionReturn(0);
> As I mentioned in the previous email, I think this is quite
> inefficient because the scattering of x during each iteration
> "requires a good chunk of communication". And as Barry pointed out, "
> the Jacobian will be dense and the linear solves with the dense
> Jacobian will dominate the time anyways. "
> So my question now is: 1. Am I right to use the PETSc TS parallel
> paradigm in this way to solve my DAE equations? My concern is although
> I can see the solution be computed across multiple processors, the
> overhead of scattering x from time to time and the linear solving with
> dense Jacobian will eat up the performance gains of parallel
> computation.
The data movement is O(N) while the computation is O(N^3), so
parallelism will be useful if N is large enough.
> 2. If the answer of the above question is "NO", what's the correct
> parallel tool I should look into in PETSc to solve my DAE equations?
> MatElemental as most of you suggested?
TS with MatElemental is right.  Here are some tests that use
MatElemental.  You should use MatGetOwnershipIS() to determine which
matrix entries you are responsible for computing.  You can use your
current code for IFunction evaluation.
src/ksp/ksp/examples/tests/ex40.c
src/mat/examples/tests/ex104.c
src/mat/examples/tests/ex145.c
src/mat/examples/tests/ex38.c
src/mat/examples/tests/ex39.c
