[petsc-users] memory crash with optimized petsc
Tue Jun 4 05:51:12 CDT 2013
On Tue, Jun 4, 2013 at 6:22 AM, Fande Kong <fande.kong at colorado.edu> wrote:
> When I used valgrind to check memory, I got the following output:
1) valgrind cannot give you a stack from executables without symbols
2) You should not care about things that go on in _dl_init()
   Matt
> ==3055== Conditional jump or move depends on uninitialised value(s)
> ==3055==    at 0x6CF359E: ??? (in
> /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
> ==3055==    by 0x6CF2B25: ??? (in
> ==3055==    by 0x6C31607: ??? (in
> ==3055==    by 0x400F305: call_init.part.0 (dl-init.c:85)
> ==3055==    by 0x400F3DE: _dl_init (dl-init.c:52)
> ==3055==    by 0x40016E9: ??? (in /lib/x86_64-linux-gnu/ld-2.15.so)
> ==3055==    by 0x47: ???
> ==3055==    by 0x7FEFFFE56: ???
> ==3055==    by 0x7FEFFFE69: ???
> ==3055==    by 0x7FEFFFE71: ???
> ==3055==    by 0x7FEFFFE75: ???
> ==3055==    by 0x7FEFFFE88: ???
> ==3055==    by 0x7FEFFFE8B: ???
> ==3055==    by 0x7FEFFFE95: ???
> ==3055==    by 0x7FEFFFE9C: ???
> ==3055==    by 0x7FEFFFEA5: ???
> ==3055==    by 0x7FEFFFEA9: ???
> ==3055==    by 0x7FEFFFEB8: ???
> ==3055==    by 0x7FEFFFEBA: ???
> ==3055==    by 0x7FEFFFECC: ???
> ==3055==
> ==3055==    at 0x6CF35A9: ??? (in
> ==3055==
> How to understand the output?
> On Mon, Jun 3, 2013 at 9:00 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Fande Kong <fande.kong at colorado.edu> writes:
>> > This was not complete. The complete result is attached.
>> With petsc-3.4, you can use PetscFunctionBeginUser and -objects_dump to
>> eliminate internal allocations from the output.  I'm guessing you missed
>> a KSPDestroy.
> Fande Kong
> Department of Computer Science
> University of Colorado at Boulder
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130604/16d17a19/attachment.html>
