[petsc-users] memory crash with optimized petsc
Fande Kong fande.kong at colorado.edu
Mon Jun 3 01:24:16 CDT 2013
Hi all,
I can correctly run my application based on the petsc ( --with-debugging =
yes). But the same code encounters memory crash when it runs with optimized
version ( --with-debugging = no) . The detailed information for errors and
results is attached. The logs for configure and make are also attached.
Now, there are several questions I want to know.
(1) What are differences between debug version and optimized version in
terms of memory management and communication?
(2) I print some memory usages. Why does the optimized version cost twice
more memory than the debug version?
(3) How to debug the optimized code to fix memory issue?
Fande Kong
Department of Computer Science
University of Colorado at Boulder
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130603/da9076eb/attachment-0001.html>
Name: make and configure.zip
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130603/da9076eb/attachment-0004.zip>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130603/da9076eb/attachment-0005.zip>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130603/da9076eb/attachment-0006.zip>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130603/da9076eb/attachment-0007.zip>
