[petsc-users] Segmentatoin fault
Wed Jul 31 10:36:38 CDT 2013
丁老师 <ztdepyahoo at 163.com> writes:
> I write a FVM code for the convection diffusion problem on a 2D
> cartesian grid.  the code can run correctly with a grid of
> 720*720. and it use only 26% of the system memory(8G) during its
> running.
How are you testing the total application memory usage?
> but if i increase the grid to 800*800, it gives me the following
> error? could you please give me some information how to resolve it.
> mpiexec -np 4 ./main
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 11
> = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP
> MESSAGES
> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault
> (signal 11) This typically refers to a problem with your application.
> Please see the FAQ page for debugging suggestions
> ztdep at linuxdell:~/Projects/CartesianPFlowingHeat2D-KDE/build> mpiexec
> -np 4 ./main write the grid to Grid.cgns sucessfully
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130731/a4200d25/attachment.pgp>
