[petsc-users] Zero pivot in LU factorisation
Toby T.W.Searle at sms.ed.ac.uk
Thu Jul 25 08:44:27 CDT 2013
Thanks, I have corrected the shift amount option and I get the same
error as when using the -st_pc_factor_shift_amount 1
I have been using the PETSc IO module to convert my matrix from sparse
coordinate format into PETSc binary. I am guessing there is some problem
with this step. I use the function:
PetscBinaryIO.PetscBinaryIO().writeMatSciPy( fh, matrix)
to convert into Petsc binary format. Is there something wrong with this?
Do I need to manually put zeros into the diagonal elements of zero rows
of B?
When I solve the problem using scipy I use dense matrices. There are
definitely entries in the matrix A at row 2395. I used python to confirm
this before I convert it to petsc format:
             column | value
LHS:    1795  10.9955742876j
           1198    (76+0j)
           1196    (72+0j)
           595      0.02j
However, the matrix is all zeros at row 2395 in B. As far as I
understand, this doesn't make my problem singular. I am sure that the
problem is not rank deficient when I solve it in scipy.
Thanks again,
Toby
On 25/07/2013 12:51, Matthew Knepley wrote:
> On Thu, Jul 25, 2013 at 6:46 AM, Toby <T.W.Searle at sms.ed.ac.uk
> <mailto:T.W.Searle at sms.ed.ac.uk>> wrote:
>     Ok, it looks like the -st_pc_factor_shift_type option is now being
>     used, thanks. Unfortunately it hasn't fixed the problem.
>     if I use the NONZERO type and a shift amount, the shift amount
>     option is not recognised and I still get the zero pivot error. If
>     I use the POSITIVE_DEFINITE type I also get the pivot error.
>     Output is below
>     Thanks,
>     Toby
>     tobymac:SLEPC toby$ mpiexec ./ex7 -f1
>     LHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc  -f2
>     RHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc -st_pc_type lu
>     -st_pc_factor_shift_type NONZERO -st_pc_shift_type_amount 1
>     Generalized eigenproblem stored in file.
>      Reading COMPLEX matrices from binary files...
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Detected zero pivot in LU factorization:
>     see http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot!
>     [0]PETSC ERROR: Empty row in matrix: row in original ordering 2395
>     in permuted ordering 3600!
> 1) You misspelled the option: -st_pc_factor_shift_amount 1
> 2) It was used, and fixed you problem on row 0, now you have a problem
> on row 2395, namely that it is missing. No
>      LU factorization routine will succeed here. You must at least put
> a diagonal 0.0 on all rows.
> 3) Same goes for the run below.
> 4) A completely empty row means your matrix is indeed rank deficient.
> I have no idea what results are coming out of
>     scipy, but they are not using factorization.
>    Matt
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 5, Sat Dec  1
>     15:10:41 CST 2012
>     [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [0]PETSC ERROR: See docs/index.html for manual pages.
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: ./ex7 on a arch-darw named tobymac by toby Thu Jul
>     25 12:41:57 2013
>     [0]PETSC ERROR: Libraries linked from /opt/local/lib
>     [0]PETSC ERROR: Configure run at Tue Jul 23 15:11:27 2013
>     [0]PETSC ERROR: Configure options --prefix=/opt/local
>     --with-valgrind-dir=/opt/local --with-shared-libraries
>     --with-scalar-type=complex --with-clanguage=C++
>     --with-superlu-dir=/opt/local --with-blacs-dir=/opt/local
>     --with-scalapack-dir=/opt/local --with-mumps-dir=/opt/local
>     --with-metis-dir=/opt/local --with-parmetis-dir=/opt/local
>     --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2 --FOPTFLAGS=-O2
>     --LDFLAGS=-L/opt/local/lib --CFLAGS="-O2 -mtune=native"
>     --CXXFLAGS="-O2 -mtune=native"
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: MatLUFactorSymbolic_SeqAIJ() line 334 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/mat/impls/aij/seq/aijfact.c
>     [0]PETSC ERROR: MatLUFactorSymbolic() line 2750 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/mat/interface/matrix.c
>     [0]PETSC ERROR: PCSetUp_LU() line 135 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/ksp/pc/impls/factor/lu/lu.c
>     [0]PETSC ERROR: PCSetUp() line 832 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/ksp/pc/interface/precon.c
>     [0]PETSC ERROR: KSPSetUp() line 278 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/ksp/ksp/interface/itfunc.c
>     [0]PETSC ERROR: STSetUp_Shift() line 94 in src/st/impls/shift/shift.c
>     [0]PETSC ERROR: STSetUp() line 280 in src/st/interface/stsolve.c
>     [0]PETSC ERROR: EPSSetUp() line 204 in src/eps/interface/setup.c
>     [0]PETSC ERROR: EPSSolve() line 109 in src/eps/interface/solve.c
>      Number of iterations of the method: 0
>      Number of linear iterations of the method: 0
>      Number of requested eigenvalues: 1
>      Stopping condition: tol=1e-08, maxit=750
>      Number of converged approximate eigenpairs: 0
>     WARNING! There are options you set that were not used!
>     WARNING! could be spelling mistake, etc!
>     Option left: name:-st_pc_shift_type_amount value: 1
>     mpiexec ./ex7 -f1 LHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc  -f2
>     -st_pc_factor_shift_type POSITIVE_DEFINITE
>     [0]PETSC ERROR:
>     15:10:41 CST 2012
>     [0]PETSC ERROR:
>     25 12:40:20 2013
>     [0]PETSC ERROR:
>     On 25/07/2013 12:34, Jose E. Roman wrote:
>         El 25/07/2013, a las 13:30, Toby escribió:
>             Hi Matt,
>             Thanks for the speedy reply. I tried using the options you
>             suggested:
>             mpiexec ./ex7 -f1
>             But I still get the warnings:
>             Option left: name:-st_pc_factor_shift_type value: NONZERO
>         By default, ST is using PCREDUNDANT. In order to use the above
>         options you must change it to e.g. PCLU.
>         That is, add -st_pc_type lu
>         Jose
>             I have tried it with just the -st_pc_type jacobi and
>             -st_ksp_view. This gives me some eigenvalues, but I don't
>             believe them (they do not appear on the spectrum which I
>             solve using LAPACK where all eigenvalues have a real part
>             less than 0). The output was very large, but consists of
>             repetitions of this:
>             mpiexec ./ex7 -f1
>             jacobi -st_ksp_view
>             KSP Object:(st_) 1 MPI processes
>                type: preonly
>                maximum iterations=10000, initial guess is zero
>                tolerances:  relative=1e-08, absolute=1e-50,
>             divergence=10000
>                left preconditioning
>                using NONE norm type for convergence test
>             PC Object:(st_) 1 MPI processes
>                type: jacobi
>                linear system matrix = precond matrix:
>                Matrix Object:   1 MPI processes
>                  type: seqaij
>                  rows=6000, cols=6000
>                  total: nonzeros=3600, allocated nonzeros=3600
>                  total number of mallocs used during MatSetValues calls =0
>                    using I-node routines: found 4080 nodes, limit used
>             is 5
>               Number of iterations of the method: 189
>               Number of linear iterations of the method: 1520
>               Number of converged approximate eigenpairs: 2
>                         k          ||Ax-kBx||/||kx||
>                1388.774454+0.001823 i     0.751726
>                1388.774441+0.001820 i     0.912665
>             Thanks again,
>             Toby
>     The University of Edinburgh is a charitable body, registered in
>     Scotland, with registration number SC005336.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130725/cf15c74d/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
Name: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130725/cf15c74d/attachment-0001.ksh>
