[petsc-users] Zero pivot in LU factorisation
Toby T.W.Searle at sms.ed.ac.uk
Thu Jul 25 06:30:25 CDT 2013
Hi Matt,
Thanks for the speedy reply. I tried using the options you suggested:
mpiexec ./ex7 -f1 LHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc  -f2
RHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc -st_pc_factor_shift_type
NONZERO -st_pc_shift_type_amount 1
But I still get the warnings:
Option left: name:-st_pc_factor_shift_type value: NONZERO
Option left: name:-st_pc_shift_type_amount value: 1
I have tried it with just the -st_pc_type jacobi and -st_ksp_view. This
gives me some eigenvalues, but I don't believe them (they do not appear
on the spectrum which I solve using LAPACK where all eigenvalues have a
real part less than 0). The output was very large, but consists of
repetitions of this:
RHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc -st_pc_type jacobi -st_ksp_view
Generalized eigenproblem stored in file.
  Reading COMPLEX matrices from binary files...
KSP Object:(st_) 1 MPI processes
   type: preonly
   maximum iterations=10000, initial guess is zero
   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
   left preconditioning
   using NONE norm type for convergence test
PC Object:(st_) 1 MPI processes
   type: jacobi
   linear system matrix = precond matrix:
   Matrix Object:   1 MPI processes
     type: seqaij
     rows=6000, cols=6000
     total: nonzeros=3600, allocated nonzeros=3600
     total number of mallocs used during MatSetValues calls =0
       using I-node routines: found 4080 nodes, limit used is 5
  Number of iterations of the method: 189
  Number of linear iterations of the method: 1520
  Number of requested eigenvalues: 1
  Stopping condition: tol=1e-08, maxit=750
  Number of converged approximate eigenpairs: 2
            k          ||Ax-kBx||/||kx||
   1388.774454+0.001823 i     0.751726
   1388.774441+0.001820 i     0.912665
Thanks again,
Toby
On 25/07/2013 11:26, Matthew Knepley wrote:
> On Thu, Jul 25, 2013 at 4:38 AM, Toby <T.W.Searle at sms.ed.ac.uk
> <mailto:T.W.Searle at sms.ed.ac.uk>> wrote:
>     Dear all,
>     I have a generalised matrix problem: A x = lambda B x. My matrix B
>     is diagonal and positive semi-definite. My matrix A is a
>     non-hermitian complex matrix.
>     My problem is essentially that when using the SLEPc generalised
>     eigenvalue solver I get the error "zero pivot in LU
>     factorisation". The rest of the below is details about the problem
>     and things I have tried so far.
>     The matrix will be at its largest about 48000 by 48000, and I want
>     to find the eigenvalues. The eigenvalues I am interested in are
>     ones with the largest real part near 0+0i. Ideally, I want to be
>     able to find them even if they are internal (i.e when there are
>     other eigenvalues with larger positive real part in the spectrum).
>     However, I would be happy if I could get it to work for problems
>     where all eigenvalues have real parts < 0 apart from the
>     eigenvalue of interest.
>     At the moment I have used the scipy linalg.eig and sparse.eigs
>     functions. As far as I know, these use LAPACK and ARPACK
>     respectively to do the heavy lifting. I have decided to see if I
>     can achieve better performance through using the SLEPc library. If
>     this is a bad decision, let me know!
>     I want to move onto using PETSc with the SLEPc eigenvalue solvers.
>     I have been trying out SLEPc using the examples provided as part
>     of the tutorial. Exercise 7 reads matricies A and B from a file
>     and outputs the solutions. I got this to work fine using the
>     matrices provided. However, if I substitute a smaller sized test
>     version of my problem (6000x6000), I get a variety of errors
>     depending on the command line arguments I supply.
>     The main problem I have is the error: "zero pivot in LU
>     factorisation!" when I use the default settings.
>     I think this might be related to the fact that B contains rows of
>     zeros, although my understanding of linear algebra is somewhat
>     basic. Is this true?
>     I have tried setting the options suggested on the petsc website,
>     -pc_factor_shift_type NONZERO etc but all I get is an additional
>     warning that these options were not used
> 1) You probably need the correct prefix for this options, e.g.
> -st_pc_factor_shift_type NONZERO
> 2) We would like to see the output of -st_ksp_view, but you probably
> need -st_pc_type jacobi for it to finish
>    Matt
>     I assumed that this was a problem with the preconditioner, so I
>     tried setting -eps_target to 0.1 and both with and without
>     specifying -st_type sinvert and shift. Still I get the same error.
>     Then I tried -st_pc_type jacobi and st_pc_type bjacobi. jacobi
>     runs, but does not produce any eigenvalues. Block jacobi does an
>     LU factorisation and gives me the same error again.
>     The default method is krylov-schur, so I have experimented with
>     the -eps_type gd and -eps_type jd options. Unfortunately these
>     seem to produce nonsense eigenvalues, which do not appear on the
>     spectrum at all when I solve using LAPACK in scipy.
>     I know my matrix problem is not singular, because I can solve it
>     using scipy.
>     Do you know of any books/guides I might need to read besides the
>     PETSC and SLEPC manuals to understand the behaviour of all these
>     different solvers?
>     The output from the case with no command line options is given below.
>     Thanks a lot for taking the time to read this!
>     Kind Regards,
>     Toby
>     tobymac:SLEPC toby$ mpiexec ./ex7 -f1
>     RHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc -eps_view
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Detected zero pivot in LU factorization:
>     see http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot!
>     [0]PETSC ERROR: Empty row in matrix: row in original ordering 2395
>     in permuted ordering 3600!
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 5, Sat Dec  1
>     15:10:41 CST 2012
>     [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [0]PETSC ERROR: See docs/index.html for manual pages.
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: ./ex7 on a arch-darw named tobymac by toby Thu Jul
>     25 10:20:40 2013
>     [0]PETSC ERROR: Libraries linked from /opt/local/lib
>     [0]PETSC ERROR: Configure run at Tue Jul 23 15:11:27 2013
>     [0]PETSC ERROR: Configure options --prefix=/opt/local
>     --with-valgrind-dir=/opt/local --with-shared-libraries
>     --with-scalar-type=complex --with-clanguage=C++
>     --with-superlu-dir=/opt/local --with-blacs-dir=/opt/local
>     --with-scalapack-dir=/opt/local --with-mumps-dir=/opt/local
>     --with-metis-dir=/opt/local --with-parmetis-dir=/opt/local
>     --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2 --FOPTFLAGS=-O2
>     --LDFLAGS=-L/opt/local/lib --CFLAGS="-O2 -mtune=native"
>     --CXXFLAGS="-O2 -mtune=native"
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: MatLUFactorSymbolic_SeqAIJ() line 334 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/mat/impls/aij/seq/aijfact.c
>     [0]PETSC ERROR: MatLUFactorSymbolic() line 2750 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/mat/interface/matrix.c
>     [0]PETSC ERROR: PCSetUp_LU() line 135 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/ksp/pc/impls/factor/lu/lu.c
>      Number of iterations of the method: 0
>      Number of linear iterations of the method: 0
>      Number of converged approximate eigenpairs: 0
>     [0]PETSC ERROR: PCSetUp() line 832 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/ksp/pc/interface/precon.c
>     [0]PETSC ERROR: KSPSetUp() line 278 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/ksp/ksp/interface/itfunc.c
>     [0]PETSC ERROR: PCSetUp_Redundant() line 176 in
>     /opt/local/var/macports/build/_Users_toby_MyPorts_scienceports_math_petsc/petsc/work/petsc-3.3-p5/src/ksp/pc/impls/redundant/redundant.c
>     [0]PETSC ERROR: STSetUp_Shift() line 94 in src/st/impls/shift/shift.c
>     [0]PETSC ERROR: STSetUp() line 280 in src/st/interface/stsolve.c
>     [0]PETSC ERROR: EPSSetUp() line 204 in src/eps/interface/setup.c
>     [0]PETSC ERROR: EPSSolve() line 109 in src/eps/interface/solve.c
>     tobymac:SLEPC toby$
>     The University of Edinburgh is a charitable body, registered in
>     Scotland, with registration number SC005336.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130725/fd116ee1/attachment.html>
An embedded and charset-unspecified text was scrubbed...
Name: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130725/fd116ee1/attachment.ksh>
