[petsc-users] How to read/write unstructured mesh in parallel
Stephen Wornom stephen.wornom at inria.fr
Wed Jul 24 11:27:04 CDT 2013
<Yes, though it's much better if you use MPI-IO collective IO. The worst is
<if every process reads a different file.
The unstructured code I use collects the different core solution on processor 0 then writes the global solution file to be used at a restart. When I have a mesh > 2 MillionNodes
I cannot execute as the RAM/core is 3.4Gb which is sufficient to execute but the virtual memory is too large and I get an error.
Three  questions:
1- If I used mpi-io to write the file, would that reduce the virtual memory needed and permit  me to run larger meshes?
2- How would I use the mpi-io routines in the oetsc library to write the files? The mesh is partitioned using metis.
3- Is there a coding example of mpi-io writes that I could use to understand how petsc functions?
Thanks if advance,
Stephen
2004 route des lucioles - BP93
Sophia Antipolis
06902 CEDEX
Tel: 04 92 38 50 54
Fax: 04 97 15 53 51
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130724/8f5435c9/attachment.vcf>
