[petsc-users] Using GAMG to speed up solving of Poisson eqn
Sat Jul 20 11:03:28 CDT 2013
TAY wee-beng <zonexo at gmail.com> writes:
> I've used the latest 3.4.2.
No, you are not.
[0]PETSC ERROR: Petsc Development HG revision:
9850aeb5d33f0b33bc931843c4b3b3b4f8df6a3b  HG Date: Tue Oct 02 22:18:53
2012 -0500
/**/[0]PETSC ERROR:
C:\Obj_tmp\ibm3d_high_Re_staggered_AB2\Debug\ibm3d_high_Re_staggered_AB2.exe
on a petsc-3.3 named USER-PC by User Sat Jul 20 15:37:40 2013/**/
/**/[0]PETSC ERROR: Libraries linked from
/cygdrive/d/wtay/Lib/petsc-3.3-dev_win32_vs2008/lib/**/
/**/[0]PETSC ERROR: Configure run at Thu Oct  4 10:01:13 2012/**/
/**/[0]PETSC ERROR: Configure options --with-cc="win32fe cl"
--with-fc="win32fe ifort" --with-cxx="win32fe cl"
--with-mpi-dir=/cygdrive/c/MPICH2/ --download-f-blas-lapack=1
--prefix=/cygdrive/d/wtay/Lib/petsc-3.3-dev_win32_vs2008
--with-debugging=1 --useThreads=0/**/
> What else do I need to provide?
You are either intentionally or accidentally running an old PETSc.  I
suspect an environment problem before any sort of code problem, so
please get your versions straight first.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130720/11ab3cc7/attachment.pgp>
