[petsc-users] Trying to set up a field-split preconditioner
Fri Jul 19 21:33:11 CDT 2013
On Fri, Jul 19, 2013 at 9:17 PM, subramanya sadasiva <potaman at outlook.com>wrote:
> Hi Matt,
> I am using Libmesh so the DM stuff is actually in the background, and
> unfortunately the matrix doesn't have a saddle point,
> I thought that
>   -ch_solve_fieldsplit_block_size 2
>   -ch_solve_fieldsplit_0_fields 0
>   -ch_solve_fieldsplit_1_fields 1
The block_size argument presumes you are using a DA. Are you?
The other two options just say select the first DM field as field 0 in this
PC, and the same with the second field. The
DM must inform the PC about the initial field decomposition.
> would inform the solver of the structure. If this doesn't work owing to
> the fact that the problem is only being solved on a section of the mesh
> (because of the reduced space method), I guess I will have to use the
> PetscSection. Does that sound right?
First, I think the right people to do this are the Libmesh people (we will
of course help them). Second, you have not said
whether you are using a structured or unstructured mesh. What DM class does
the solver actually see?
      Matt
> Thanks,
> Subramanya
> Subject: Re: [petsc-users] Trying to set up a field-split preconditioner
> From: knepley at gmail.com
> To: potaman at outlook.com
> CC: petsc-users at mcs.anl.gov; libmesh-users at lists.sourceforge.net
> On Fri, Jul 19, 2013 at 7:56 PM, subramanya sadasiva <potaman at outlook.com>wrote:
>  Hi,
> I am trying to set up a fieldsplit preconditioner for my Cahn Hilliard
> solver and I get the following error,
> You have to tell the PCFIELDSPLIT about the dofs in each field. So
> 1) You are probably not using a DA, since it would tell it automatically
> 2) If you have a saddle point, you can use
> -pc_fieldsplit_detect_saddle_point
> 3) If none of those apply, you can set a PetscSection describing your
> layout to the DM for the solver.
>      Since this is new, I suspect you will need help, so mail back.
>   Thanks,
>      Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data!
> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 0!
> [0]PETSC ERROR:
> These are the options that I am using,
> -ch_solve is just a prefix.
> -ch_solve_pc_type fieldsplit
> -ch_solve_pc_fieldsplit_type schur
> -ch_solve_fieldsplit_0_field 1
> -ch_solve_fieldsplit_1_field 0
> -ch_solve_fieldsplit_0_ksp_type cg
> -ch_solve_fieldsplit_0_pc_type hypre
> -ch_solve_fieldsplit_0_pc_type_hypre boomeramg
> -ch_solve_fieldsplit_1_ksp_type cg
> -ch_solve_fieldsplit_1_pc_type hypre
> -ch_solve_fieldsplit_1_pc_type_hypre boomeramg
> Any ideas?
> Thanks,
> Subramanya
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130719/da67a1e8/attachment.html>
