[petsc-users] Fwd: PETSc installation on Intrepid
Richard Tran Mills rtm at eecs.utk.edu
Wed Jul 17 15:26:38 CDT 2013
Hi Satish,
I think something for handling the libz problem must be missing. I just
tried configuring on Intrepid with the configure script appended to this
email and I get the same problem:
Compression library [libz.a or equivalent] not found
I believe that the library that I need is present on the system:
rmills at login1.intrepid:~/proj/petsc> ls -l /soft/apps/zlib-1.2.3/lib/
total 128
-rwxrwxr-x 1 rloy software 108724 2010-04-21 01:35 libz.a
Any ideas on what I need to do to get configure.py to find and use this?
Richard
#!/usr/bin/python
if __name__ == '__main__':
   import sys
   import os
   sys.path.insert(0, os.path.abspath('config'))
   import configure
   configure_options = [
     '--with-hdf5-dir=/soft/apps/current/hdf5-1.8.9',
     '--download-cmake=1',
     '--download-metis=1',
     '--download-parmetis=1',
     '--known-bits-per-byte=8',
     '--known-level1-dcache-assoc=0',
     '--known-level1-dcache-linesize=32',
     '--known-level1-dcache-size=32768',
     '--known-memcmp-ok=1',
     '--known-mpi-long-double=1',
     '--known-mpi-shared-libraries=0',
     '--known-sizeof-MPI_Comm=4',
     '--known-sizeof-MPI_Fint=4',
     '--known-sizeof-char=1',
     '--known-sizeof-double=8',
     '--known-sizeof-float=4',
     '--known-sizeof-int=4',
     '--known-sizeof-long-long=8',
     '--known-sizeof-long=4',
     '--known-sizeof-short=2',
     '--known-sizeof-size_t=4',
     '--known-sizeof-void-p=4',
     '--prefix=/soft/apps/libraries/petsc/3.3-p2/xl-opt',
     '--with-batch=1',
#'--with-blacs-include=/soft/apps/libraries/alcf/current/xl/SCALAPACK/',
#'--with-blacs-lib=/soft/apps/libraries/alcf/current/xl/SCALAPACK/lib/libscalapack.a',
'--with-blas-lapack-lib=-L/soft/apps/libraries/alcf/current/xl/LAPACK/lib
-llapack -L/soft/apps/libraries/alcf/current/xl/BLAS/lib -lblas',
     '--with-cc=mpixlc_r',
     '--with-cxx=mpixlcxx_r',
     '--with-debugging=0',
     '--with-fc=mpixlf77_r -qnosave',
     '--with-fortran-kernels=1',
     '--with-is-color-value-type=short',
'--with-scalapack-include=/soft/apps/libraries/alcf/current/xl/SCALAPACK/',
'--with-scalapack-lib=/soft/apps/libraries/alcf/current/xl/SCALAPACK/lib/libscalapack.a',
     '--with-shared-libraries=0',
     '--with-x=0',
     '--with-debugging=1',
     '-COPTFLAGS=-g',
     '-CXXOPTFLAGS=-g',
     '-FOPTFLAGS=-g',
   configure.petsc_configure(configure_options)
On 7/16/13 12:59 PM, Satish Balay wrote:
> --download-package might not work on all machines. --download-hdf5=1 does
> not work on bg/p
> However there is hdf5 installed on it. You can try using
> --with-hdf5-include/--with-hdf5-lib options.
> There could still be an issue with "Compression library [libz.a or
> equivalent] not found" but I think the workarround is already in
> petsc-dev.
> Satish
> On Tue, 16 Jul 2013, Jitendra Kumar wrote:
>> Thanks Satish. I tried using the configuration you pointed me to with the
>> addition of --download-hdf5=1 and got error "Compression library [libz.a or
>> Do I need to load some package to get this?
>> Jitu
>> On Tue, Jul 16, 2013 at 11:59 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> As the message indicates you need '--with-batch' option on this machine
>>> Check one of the default builds on intrepid for configure options to use..
>>> [perhaps
>>> /soft/apps/libraries/petsc/3.3-p6/xl-opt/conf/reconfigure-arch-bgp-ibm-opt.py]
>>> Satish
>>>> I ran into following errors while trying to build PETSc-dev on Intrepid
>>>> @ALCF.  (configure.log attached)
>>>>           UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>>>> details):
>>>> Cannot run executable to determine size of char. If this machine uses a
>>>> batch system
>>>> to submit jobs you will need to configure using ./configure with the
>>>> additional option  --with-batch.
>>>>   Otherwise there is problem with the compilers. Can you compile and run
>>>> code with your C/C++ (and maybe Fortran) compilers?
>>>>    File "/gpfs/home/jkumar/lib/petsc/config/configure.py", line 293, in
>>>> petsc_configure
>>>>      framework.configure(out = sys.stdout)
>>>>    File
>>>> "/gpfs/home/jkumar/lib/petsc/config/BuildSystem/config/framework.py",
>>> line
>>>> 933, in configure
>>>>      child.configure()
>>>>    File "/gpfs/home/jkumar/lib/petsc/config/BuildSystem/config/types.py",
>>>> line 386, in configure
>>>>      map(lambda type: self.executeTest(self.checkSizeof, type),
>>>> ['char','void *', 'short', 'int', 'long', 'long long', 'float', 'double',
>>>> 'size_t'])
>>>> line 386, in <lambda>
>>>> 'size_t'])
>>>>    File "/gpfs/home/jkumar/lib/petsc/config/BuildSystem/config/base.py",
>>>> line 115, in executeTest
>>>>      ret = apply(test, args,kargs)
>>>> line 296, in checkSizeof
>>>>      raise RuntimeError(msg)
>>>> This is what my configuration looks like (adapted from
>>>> config/examples/arch-bgp-ibm-opt.py)
>>>>    '--with-cc=mpixlc',
>>>>    '--with-fc=mpixlf90',
>>>>    '--with-cxx=mpixlcxx',
>>>>    'COPTFLAGS=-O3',
>>>>    'FOPTFLAGS=-O3',
>>>>    '--with-cmake=/soft/apps/fen/cmake-2.8.3/bin/cmake',
>>>> #  '--with-hdf5=/soft/apps/hdf5-1.8.0',
>>>>    '--download-plapack=1',
>>>>    '--download-hdf5=1'
>>>> I would appreciate any help building the llbrary there.
>>>> Thanks,
>>>> Jitu
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
