[petsc-users] installing petsc with scalapack from mkl
Wed Jul 17 06:06:10 CDT 2013
On Wed, Jul 17, 2013 at 2:47 AM, Inge Gutheil <i.gutheil at fz-juelich.de>wrote:
> Hello,
> I tried this and got the following error:
1) Please do not send logs to petsc-users, send them to
petsc-maint at mcs.anl.gov
2) The logic is wrong here. We are requiring you to also specify an empty
--with-scalapack-include=[],
     which you should not have to. Please confirm that this works.
We will put a fix in the next patch update.
     Matt
> TEST configureLibrary from
> PETSc.packages.scalapack(/**lustre/jhome5/software/**
> mathprod/PETSc/petsc-3.4.2/**config/BuildSystem/config/**package.py:464)
> TESTING: configureLibrary from
>   Find an installation and check if it can work with PETSc
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> You must specify a path for scalapack with --with-scalapack-dir=<**
> directory>
> If you do not want scalapack, then give --with-scalapack=0
> You might also consider using --download-scalapack instead
>   File
> "/lustre/jhome5/software/**mathprod/PETSc/petsc-3.4.2/**config/configure.py",
> line
> 293, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File
> config/BuildSystem/config/**framework.py",
> line 933, in configure
>     child.configure()
>   File
> config/BuildSystem/config/**package.py",
> line 556, in configure
>     self.executeTest(self.**configureLibrary)
>   File
> config/BuildSystem/config/**base.py",
> line 115, in executeTest
>     ret = apply(test, args,kargs)
>   File
> line 484, in configureLibrary
>     for location, directory, lib, incl in self.generateGuesses():
>   File
> line 314, in generateGuesses
>     raise RuntimeError('You must specify a path for '+self.name+' with
> --with-'+self.package+'-dir=<**directory>\nIf you do not want
> '+self.name+', then give --with-'+self.package+'=0\nYou might also
> consider using --download-'+self.package+' instead')
> See the attached complete configure.log
> This is on an intel cluster with intel compiler.
> Thanks
> Inge Gutheil
> On 07/16/13 17:27, Satish Balay wrote:
>> Try:
>> --with-scalapack-lib="-L/opt/**intel/mkl//lib/intel64
>> -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64"
>> BLACS is now part of scalapack-2 [which petsc-3.4 uses] - but mkl has
>> blas/scalapack split.
>> So you would have to specify both libs with the --with-scalapack-lib
>> option.
>> Satish
>> On Tue, 16 Jul 2013, Michael Povolotskyi wrote:
>>  Dear Petsc developers and users,
>>> I'm trying to configure petsc with scalapack from mkl library.
>>>  From the configure.log (see attached) it seems that when PETSc checks
>>> for the
>>> scalapack functionality it does not link blacs.
>>> Please advise.
>>> Thank you,
>>> Michael.
> Inge Gutheil
> Juelich Supercomputing Centre
> Institute for Advanced Simulation
> Forschungszentrum Juelich GmbH
> 52425 Juelich, Germany
>       Phone:   +49-2461-61-3135
>       Fax:     +49-2461-61-6656
>       E-mail:i.gutheil at fz-juelich.de
> 52425 Juelich
> Sitz der Gesellschaft: Juelich
> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
> Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
> Prof. Dr. Sebastian M. Schmidt
> Das Forschungszentrum oeffnet seine Tueren am Sonntag, 29. September, von
> 10:00 bis 17:00 Uhr: http://www.tagderneugier.de
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130717/983554f0/attachment.html>
