[petsc-users] Extracting data from a Petsc matrix
Harshad Sahasrabudhe hsahasra at purdue.edu
Tue Jul 16 14:26:22 CDT 2013
Yes, they has the same calling sequence for LU factorization. Thanks a
lot! Will look into this.
Harshad
On 07/16/2013 03:22 PM, Barry Smith wrote:
> On Jul 16, 2013, at 2:18 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu> wrote:
>> Hi Barry,
>> I'm confused, can you please explain what you meant by 'MAGMA has a calling sequence like LAPACK'?
> Here is how we call lapack Cholesky factorization from PETSc:
> #undef __FUNCT__
> #define __FUNCT__ "MatCholeskyFactor_SeqDense"
> PetscErrorCode MatCholeskyFactor_SeqDense(Mat A,IS perm,const MatFactorInfo *factinfo)
> #if defined(PETSC_MISSING_LAPACK_POTRF)
>    PetscFunctionBegin;
>    SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"POTRF - Lapack routine is unavailable.");
> #else
>    Mat_SeqDense   *mat = (Mat_SeqDense*)A->data;
>    PetscErrorCode ierr;
>    PetscBLASInt   info,n;
>    PetscFunctionBegin;
>    ierr = PetscBLASIntCast(A->cmap->n,&n);CHKERRQ(ierr);
>    ierr = PetscFree(mat->pivots);CHKERRQ(ierr);
>    if (!A->rmap->n || !A->cmap->n) PetscFunctionReturn(0);
>    PetscStackCallBLAS("LAPACKpotrf",LAPACKpotrf_("L",&n,mat->v,&mat->lda,&info));
>    if (info) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_MAT_CH_ZRPVT,"Bad factorization: zero pivot in row %D",(PetscInt)info-1);
>    A->ops->solve             = MatSolve_SeqDense;
>    A->ops->solvetranspose    = MatSolveTranspose_SeqDense;
>    A->ops->solveadd          = MatSolveAdd_SeqDense;
>    A->ops->solvetransposeadd = MatSolveTransposeAdd_SeqDense;
>    A->factortype             = MAT_FACTOR_CHOLESKY;
>    ierr = PetscLogFlops((A->cmap->n*A->cmap->n*A->cmap->n)/3.0);CHKERRQ(ierr);
> #endif
>     If Magma has a calling sequence similar to LAPACKpotrf_("L",&n,mat->v,&mat->lda,&info)); then you could model your code on the routine above instead of typing in all new code that does almost the exact same thing.
>     Barry
>> Thanks,
>> Harshad
>> On 07/16/2013 02:48 PM, Barry Smith wrote:
>>>     Read all of http://www.mcs.anl.gov/petsc/developers/index.html
>>>      Note that if Magma has a calling sequence like lapack you could possible steal chunks of code from the routines I pointed you to yesterday and modify them as needed so you don't need to reinvent the wheel.
>>>     Barry
>>> On Jul 16, 2013, at 1:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Tue, Jul 16, 2013 at 1:13 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu> wrote:
>>>> Hi Jed,
>>>> Thanks for your reply.
>>>> You're on your own for storage of factors.  Alternatively, you could add
>>>> library support so that you could use PCLU and
>>>> '-pc_factor_mat_solver_package magma' (or PCFactorSetMatSolverPackage).
>>>> Doing this is not a priority for us, but we can provide guidance if you
>>>> want to tackle it.
>>>> I would definitely like to start working on adding library support. I think this is the most efficient way to go about it. Can you give me certain details such as:
>>>> 1) How should I start going about it?
>>>> Read the UMFPACK implementation
>>>>   2) How will I check-in the changes to Petsc?
>>>> Using Git
>>>>   3) What version of Petsc will the changes be reflected in if I started working on it right now?
>>>> A branch of 'master'
>>>>   4) How many hours does it generally take to get this done?
>>>> How many licks does it take to get to the center of a Tootsie Roll Pop?
>>>>   5) How is the peer review done?
>>>> Through a pull request on BitBucket.
>>>>    Thanks,
>>>>       Matt
>>>>   Thanks,
>>>> Harshad
>>>> On 07/13/2013 12:43 PM, Jed Brown wrote:
>>>> "hsahasra at purdue.edu" <hsahasra at purdue.edu> writes:
>>>> Hi,
>>>> I am working on solving a system of linear equations with square
>>>> matrix. I'm first factoring the matrix using LU decomposition.
>>>> I assume you're solving a dense problem because that is all MAGMA does.
>>>> I want to do the LU decomposition step using MAGMA on GPUs. MAGMA
>>>> library implements LAPACK functions on a CPU+GPU based system.
>>>> So my question is, how do I extract the data from a Petsc Mat so that
>>>> it can be sent to the dgetrf routine in MAGMA.
>>>> MatDenseGetArray
>>>> Is there any need for duplicating the data for this step?
>>>> want to tackle it.
>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>> -- Norbert Wiener
