[petsc-users] Extracting data from a Petsc matrix
Tue Jul 16 13:37:12 CDT 2013
On Tue, Jul 16, 2013 at 1:13 PM, Harshad Sahasrabudhe
<hsahasra at purdue.edu>wrote:
> Hi Jed,
> Thanks for your reply.
>  You're on your own for storage of factors.  Alternatively, you could add
>> library support so that you could use PCLU and
>> '-pc_factor_mat_solver_package magma' (or PCFactorSetMatSolverPackage).
>> Doing this is not a priority for us, but we can provide guidance if you
>> want to tackle it.
> I would definitely like to start working on adding library support. I
> think this is the most efficient way to go about it. Can you give me
> certain details such as:
> 1) How should I start going about it?
Read the UMFPACK implementation
> 2) How will I check-in the changes to Petsc?
Using Git
> 3) What version of Petsc will the changes be reflected in if I started
> working on it right now?
A branch of 'master'
> 4) How many hours does it generally take to get this done?
How many licks does it take to get to the center of a Tootsie Roll Pop?
> 5) How is the peer review done?
Through a pull request on BitBucket.
     Matt
> Thanks,
> Harshad
> On 07/13/2013 12:43 PM, Jed Brown wrote:
>> "hsahasra at purdue.edu" <hsahasra at purdue.edu> writes:
>>  Hi,
>>> I am working on solving a system of linear equations with square
>>> matrix. I'm first factoring the matrix using LU decomposition.
>> I assume you're solving a dense problem because that is all MAGMA does.
>>  I want to do the LU decomposition step using MAGMA on GPUs. MAGMA
>>> library implements LAPACK functions on a CPU+GPU based system.
>>> So my question is, how do I extract the data from a Petsc Mat so that
>>> it can be sent to the dgetrf routine in MAGMA.
>> MatDenseGetArray
>>  Is there any need for duplicating the data for this step?
>> want to tackle it.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130716/b98bc6f4/attachment.html>
