[petsc-users] default orthogonalization in gmres
Mon Jul 15 16:57:13 CDT 2013
Karl Rupp <rupp at mcs.anl.gov> writes:
> However, for Gram-Schmidt you can just compute all the
> necessary scalar products at the same time (VecMDot) and reuse the
> common data vector. This gives you a speed-up of a factor of almost two.
It's not a factor of 2, it's a factor of k where k is the size of the
subspace.  Classical Gram-Schmidt needs one reduction per iteration
(normalization can be hidden), but modified needs k reductions.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130715/b0aeb6a9/attachment-0001.pgp>
