[petsc-users] [Libmesh-users] Really Really Really Weird SNES behaviour
Kirk, Benjamin (JSC-EG311) benjamin.kirk-1 at nasa.gov
Sun Jul 14 09:19:01 CDT 2013
Have you tried devel mode? It uses compiler flags similar to optimized mode but leaves asserts on too.
Otherwise, I agree with Cody that there may be an uninitialized value that is silently being set to 0 in debug mode but contains garbage in optimized mode.
-Ben
On Jul 14, 2013, at 7:26 AM, "Cody Permann" <codypermann at gmail.com> wrote:
> Sounds like a memory corruption problem. I know several users that are
> experts at writing code like that.
> Unfortunately, it can be difficult to track down on OS X due to a lack
> of working memory analysis tools.
> 1. Since this problem popped up after you changed your initial
> condition, you may just want to start by carefully looking at your
> code and thinking about cases where your variables might not be
> initialized, or where calculations could potentially produce underflow
> or overflow conditions.
> 2. If you have access to a Linux box, then you will have bounds
> checked STL containers at your disposal in debug mode.  You'll also be
> able to run your code through valgrind.  Both of those operations are
> relatively easy to perform.  Let us know if you have any questions.
> Cody
> Sent from my iPhone
> On Jul 13, 2013, at 11:17 PM, subramanya sadasiva <potaman at outlook.com> wrote:
>> Hi, I am observing some really really really weird SNES behavior in my SNESVI code called through Libmesh. This behaviour appeared after I changed some initial conditions and only happens in an optimized build. I am running this code on a Macbook pro running os x 10.8..
>> When the debug code is run, the residuals computed for the initial conditions provided give norms which are of the expected magnitude.. so the SNES_Monitor output is,
>> solving the cahn hilliard time step  0 SNES Function norm 8.223262421671e-01  1 SNES Function norm 3.793806858333e-03Nonlinear solve did not converge due to DIVERGED_MAX_IT iterations 1
>> The output from SNES_Monitor with the optimized code on the other hand is,
>> solving the cahn hilliard time step  0 SNES Function norm 5.153882032022e+19  1 SNES Function norm 1.446612980133e+19Nonlinear solve did not converge due to DIVERGED_MAX_IT iterations 1
>> Absolutely nothing else has changed in the code except that one code is built with a debugging and one with an optimized version of the code.
>> Any ideas?Subramanya
>> See everything from the browser to the database with AppDynamics
>> Get end-to-end visibility with application monitoring from AppDynamics
>> Isolate bottlenecks and diagnose root cause in seconds.
>> Start your free trial of AppDynamics Pro today!
>> http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
>> Libmesh-users mailing list
>> Libmesh-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/libmesh-users
