[petsc-users] GAMG PC dependence on right-hand side
Thu Jul 11 13:00:51 CDT 2013
John Mousel <john.mousel at gmail.com> writes:
> I'm trying to reuse the PC constructed by GAMG during a sub-iterative
> procedure where KSPSolve is called with the same matrix repeatedly. The
> right-hand side changes during the sub-iteration. I've been attempting to
> use SAME_PRECONDITIONER for nit = 2...,
What do you mean by SAME_PRECONDITIONER?  If you are solving with the
same matrix, you can just call KSPSolve without KSPSetOperators.
> Is there a dependence on the right-hand side in GAMG somewhere?
It uses a pseudo-random number generator for eigenvalue estimation.  Try
adding
  -random_seed 1
to your run and see if it cuts the variation you see.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130711/c55001f7/attachment.pgp>
