[petsc-users] compile petsc with intel compiler
Klaus Zimmermann klaus.zimmermann at physik.uni-freiburg.de
Wed Jul 10 10:50:38 CDT 2013
Hi Michael,
for what it's worth, I have built petsc 3.1 and 3.2 with the intel
compiler. It went smoothly ones I had the mpi environment set up. Your
output looks to me like your mpicc and/or mpiicc is still calling gcc.
Could you confirm your mpicc actually calls icc by looking at
mpicc --version
Best
Klaus
Am 10.07.2013 17:14, schrieb Michael Povolotskyi:
> Everything was installed by synaptic that calls dpkg.
> I'm reconfiguring and will let you know.
> Michael.
> On 07/10/2013 11:12 AM, Satish Balay wrote:
>> Hm - thats wierd. Was it installed by dpkg or something else?
>> On my ubuntu 12.04 box - I get:
>> balay at petsc^~ $ locate bits/c++config.h
>> /usr/include/c++/4.4/x86_64-linux-gnu/32/bits/c++config.h
>> /usr/include/c++/4.4/x86_64-linux-gnu/bits/c++config.h
>> /usr/include/c++/4.6/x86_64-linux-gnu/32/bits/c++config.h
>> /usr/include/c++/4.6/x86_64-linux-gnu/bits/c++config.h
>> You can try specifing the include path with CXXCPPFLAGS [for the c++
>> compiler]
>> Satish
>> On Wed, 10 Jul 2013, Michael Povolotskyi wrote:
>>> Hi Satish,
>>> it looks like I have this file but not in "standard" location:
>>> /usr/include/x86_64-linux-gnu/c++/4.7/bits/c++config.h
>>> /usr/share/gccxml-0.9/GCC/4.4/bits/c++config.h
>>> /usr/share/gccxml-0.9/GCC/4.6/bits/c++config.h
>>> /usr/share/gccxml-0.9/GCC/4.7/bits/c++config.h
>>> Should I try to add -I usr/include/x86_64-linux-gnu/c++/4.7/ to the
>>> CPPLAGS?
>>> Michael.
>>> On 07/10/2013 10:41 AM, Satish Balay wrote:
>>>> Perhaps stuff is not installed correctly on this machine?
>>>> [petsc:~] petsc> dpkg -S /usr/include/c++/4.6/bits/stl_algobase.h
>>>> libstdc++6-4.6-dev: /usr/include/c++/4.6/bits/stl_algobase.h
>>>> libstdc++6-4.6-dev:
>>>> [petsc:~] petsc>
>>>> So both bits/stl_algobase.h and bits/c++config.h are installed by
>>>> libstdc++
>>>> package.
>>>> What do you have for:
>>>> ls /usr/include/c++/4.7/bits/stl_algobase.h
>>>> ls /usr/include/c++/4.7/x86_64-linux-gnu/bits/c++config.h
>>>> dpkg -S /usr/include/c++/4.7/bits/stl_algobase.h
>>>> dpkg -S /usr/include/c++/4.7/x86_64-linux-gnu/bits/c++config.h
>>>> [perhaps the files exist - but the intel compiler is not finding it?]
>>>> Satish
>>>>> Thank you Matt.
>>>>> Unfortunately 'make all-legacy' gives the same error:
>>>>> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src
>>>>> libfast in: /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys
>>>>> libfast in:
>>>>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes
>>>>> libfast in:
>>>>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer
>>>>> libfast in:
>>>>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls
>>>>> libfast in:
>>>>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/classes/viewer/impls/socket
>>>>> /usr/include/c++/4.7/bits/stl_algobase.h(60): catastrophic error:
>>>>> cannot
>>>>> open
>>>>> source file "bits/c++config.h"
>>>>>     #include <bits/c++config.h>
>>>>> compilation aborted for send.c (code 4)
>>>>> Michael.
>>>>> On 07/10/2013 08:05 AM, Matthew Knepley wrote:
>>>>>> On Wed, Jul 10, 2013 at 12:00 AM, Michael Povolotskyi
>>>>>> <mpovolot at purdue.edu
>>>>>> <mailto:mpovolot at purdue.edu>> wrote:
>>>>>>       Hello everybody,
>>>>>>       unfortunately building petsc without fortran cannot work for me
>>>>>>       because I need MUMPs that requires Scalapack that needs
>>>>>> fortran. I
>>>>>>       played with the options. As result the configuration runs okay,
>>>>>>       the build gives an error that does not seem to be related to
>>>>>> fortran:
>>>>>> Quit building with CMake. It complicates everything. Use the legacy
>>>>>> build.
>>>>>>      Matt
>>>>>>       [  0%] Building CXX object
>>>>>>       CMakeFiles/petscsys.dir/src/sys/totalview/tv_data_display.c.o
>>>>>>       Building Fortran object
>>>>>>       CMakeFiles/petscsys.dir/src/sys/f90-mod/petscsysmod.F.o
>>>>>>       Building CXX object
>>>>>>       CMakeFiles/petscsys.dir/src/sys/python/pythonsys.c.o
>>>>>>       [  0%] /usr/include/c++/4.7/bits/stl_algobase.h(60):
>>>>>> catastrophic
>>>>>>       error: cannot open source file "bits/c++config.h"
>>>>>> error:
>>>>>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/info/verboseinfo.c
>>>>>>       (code 4)
>>>>>> /home/mpovolot/Code_intel/libs/petsc/build-real/src/sys/logging/plog.c
>>>>>>       (code 4)
>>>>>>       I attach here the log files.
>>>>>>       Any advise is highly appreciated.
>>>>>>       Michael.
>>>>>>       On 7/9/2013 4:34 PM, Matthew Knepley wrote:
>>>>>>>       On Tue, Jul 9, 2013 at 3:32 PM, Michael Povolotskyi
>>>>>>>       <mpovolot at purdue.edu <mailto:mpovolot at purdue.edu>> wrote:
>>>>>>>           If I  do not need to use petsc in fortran programs, can I
>>>>>>>           build petsc without fortran and thus avoid this situation?
>>>>>>>           Michael.
>>>>>>>           On 07/09/2013 04:31 PM, Satish Balay wrote:
>>>>>>>               For some reason this issue comes up with mpi.mod
>>>>>>> provided
>>>>>>>               by intel
>>>>>>>               mpi.
>>>>>>>               We have a configure test for it - but looks like
>>>>>>> its not
>>>>>>>               sufficient to
>>>>>>>               catch this issue.
>>>>>>>               satish
>>>>>>>               On Tue, 9 Jul 2013, Matthew Knepley wrote:
>>>>>>>                   On Tue, Jul 9, 2013 at 3:11 PM, Michael
>>>>>>> Povolotskyi
>>>>>>> <mailto:mpovolot at purdue.edu>>wrote:
>>>>>>>                       Dear Petsc users and developers,
>>>>>>>                       I'm trying to build petsc with Intel compiler.
>>>>>>>                   1) First, ask yourself whether you really want to
>>>>>>>                   build with the Intel
>>>>>>>                   compiler. Then ask again.
>>>>>>>                   2) Do you need Fortran? If not, turn it off
>>>>>>> --with-fc=0.
>>>>>>>            Matt
>>>>>>>                   3) If you want Fortran and Intel (and have a
>>>>>>> hatred
>>>>>>>                   of free time), try the
>>>>>>>                   legacy build
>>>>>>>                       make all-legacy
>>>>>>>                   4) If this is still broken, send the new make.log
>>>>>>>                      Thanks,
>>>>>>>                        Matt
>>>>>>>                       The configuration process runs okay (I
>>>>>>> attach the
>>>>>>>                       log here),
>>>>>>>                       but I get an error when I build it:
>>>>>>>                       -- Configuring done
>>>>>>>                       -- Generating done
>>>>>>>                       -- Build files have been written to:
>>>>>>>                       /home/mpovolot/Code_intel/**
>>>>>>>                       libs/petsc/build-real/linux
>>>>>>>                       Scanning dependencies of target petscsys
>>>>>>>                       [  0%] [  0%] [  0%] Building CXX object
>>>>>>>                       CMakeFiles/petscsys.dir/src/**
>>>>>>>                       sys/info/verboseinfo.c.o
>>>>>>>                       Building CXX object
>>>>>>>                       sys/totalview/tv_data_display.**c.o
>>>>>>>                       Building CXX object
>>>>>>> CMakeFiles/petscsys.dir/src/**sys/python/pythonsys.c.o
>>>>>>>                       Building CXX object
>>>>>>> CMakeFiles/petscsys.dir/src/**sys/logging/plog.c.o
>>>>>>> /home/mpovolot/Code_intel/**libs/petsc/build-real/src/sys/**
>>>>>>>                       f90-mod/petscsysmod.F:6.11:
>>>>>>>                                use mpi
>>>>>>>                                   1
>>>>>>>                       Fatal Error: File 'mpi.mod' opened at (1)
>>>>>>> is not
>>>>>>>                       a GFORTRAN module file
>>>>>>>                       make[6]: ***
>>>>>>> [CMakeFiles/petscsys.dir/src/**sys/f90-mod/petscsysmod.F.o]
>>>>>>>                       Error 1
>>>>>>>                       make[6]: *** Waiting for unfinished jobs....
>>>>>>>                       make[5]: *** [CMakeFiles/petscsys.dir/all]
>>>>>>> Error
>>>>>>> 2
>>>>>>>                       make[4]: *** [all] Error 2
>>>>>>>                       make[3]: *** [ccmake] Error 2
>>>>>>>                       make[2]: *** [cmake] Error 2
>>>>>>> ****************************ERROR**************************************
>>>>>>>                          Error during compile, check
>>>>>>> linux/conf/make.log
>>>>>>>                          Send it and linux/conf/configure.log to
>>>>>>>                       petsc-maint at mcs.anl.gov
>>>>>>>                       <mailto:petsc-maint at mcs.anl.gov>
>>>>>>>                       I attach here the make.log
>>>>>>>                       What is strange to me that it has something
>>>>>>> to do
>>>>>>>                       with Gfortran, while I
>>>>>>>                       want to build everything with Intel.
>>>>>>>                       Thank you for help,
>>>>>>>                       Michael.
>>>>>>>                       Michael Povolotskyi, PhD
>>>>>>>                       Research Assistant Professor
>>>>>>>                       Network for Computational Nanotechnology
>>>>>>>                       207 S Martin Jischke Drive
>>>>>>>                       Purdue University, DLR, room 441-10
>>>>>>>                       West Lafayette, Indiana 47907
>>>>>>>                       phone: +1-765-494-9396 <tel:%2B1-765-494-9396>
>>>>>>>                       fax: +1-765-496-6026 <tel:%2B1-765-496-6026>
>>>>>>>       --     What most experimenters take for granted before they
>>>>>>> begin
>>>>>>> their
>>>>>>>       experiments is infinitely more interesting than any results to
>>>>>>>       which their experiments lead.
>>>>>>>       -- Norbert Wiener
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments
>>>>>> is infinitely more interesting than any results to which their
>>>>>> experiments
>>>>>> lead.
>>>>>> -- Norbert Wiener
