[petsc-users] Error message Exit Code 9
Garnet Vaz garnet.vaz at gmail.com
Tue Jul 9 17:09:45 CDT 2013
Dear all,
My PETSc code crashes with the output
Number of lines in file is 5349000  #<----- Number of points
Number of lines in file is 10695950  #<----- Number of triangles
reading cell list successful
reading vertex list successful
Mesh distribution successful
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 9
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Killed (signal 9)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
I am using a debug version of PETSc. The same code has been working
for smaller meshes (upto 3M triangles). I have run the code through valgrind
and it reports no memory leaks for a smaller mesh.
All my functions use PetscFunctionBegin()/End()
which usually reports me the function causing the problem. In this case,
the output does not help except for the exit code = 9. What does this mean?
Garnet Vaz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130709/2f46a457/attachment.html>
