[petsc-users] compile petsc with intel compiler
Michael Povolotskyi mpovolot at purdue.edu
Tue Jul 9 16:17:24 CDT 2013
On 07/09/2013 04:37 PM, Satish Balay wrote:
> On Tue, 9 Jul 2013, Michael Povolotskyi wrote:
>> Dear Petsc users and developers,
>> I'm trying to build petsc with Intel compiler.
>> What is strange to me that it has something to do with Gfortran, while I want
>> to build everything with Intel.
> Looks like you are not using intel compilers - just intel mpi
> Satish.
Hello Satish,
I tried to specify exactly that I want to use Intel compilers:
./config/configure.py --with-x=0 --with-hdf5 --download-hdf5=1
--with-scalar-type=real --with-single-library=0  --with-pic=1
--with-shared-libraries=0 --with-mpi-dir=/opt/intel/impi/4.1.0/ \
          --with-clanguage=C++ --with-fortran --with-debugging=1
--with-cc="/opt/intel/impi/4.1.0/intel64/bin/mpiicc
-cc=/opt/intel/bin/icc"
--with-fc="/opt/intel/impi/4.1.0/intel64/bin/mpiifort
-fc=/opt/intel/bin/ifort"
--with-cxx="/opt/intel/impi/4.1.0/intel64/bin/mpiicpc
-cxx=/opt/intel/bin/icpc " COPTFLAGS="-O3" CXXOPTFLAGS="-O3"
FOPTFLAGS="-O3"  --download-metis=1 --download-parmetis=1
--download-mumps=1
--download-scalapack=/home/mpovolot/Code_intel/libs/petsc/scalapack-2.0.2.tgz
--with-fortran-kernels=1  --with-blas-lapack-dir=/opt/intel/mkl/
--download-blacs=1;
But I get the following error message:
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
--with-cc=/opt/intel/impi/4.1.0/intel64/bin/mpiicc
-cc=/opt/intel/bin/icc is specified with
--with-mpi-dir=/opt/intel/impi/4.1.0/. However
/opt/intel/impi/4.1.0/bin/mpicc exists and should be the prefered
compiler! Suggest not specifying --with-cc option so that configure can
use /opt/intel/impi/4.1.0/bin/mpicc instead.
   File "./config/configure.py", line 293, in petsc_configure
     framework.configure(out = sys.stdout)
   File
"/home/mpovolot/Code_intel/libs/petsc/build-real/config/BuildSystem/config/framework.py",
line 933, in configure
     child.configure()
   File
"/home/mpovolot/Code_intel/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py",
line 1524, in configure
     self.executeTest(self.checkMPICompilerOverride)
   File
"/home/mpovolot/Code_intel/libs/petsc/build-real/config/BuildSystem/config/base.py",
line 115, in executeTest
     ret = apply(test, args,kargs)
   File
line 1492, in checkMPICompilerOverride
     raise RuntimeError(msg)
Thank you,
Michael.
