[petsc-users] compile petsc with intel compiler
Michael Povolotskyi mpovolot at purdue.edu
Tue Jul 9 15:32:48 CDT 2013
If I  do not need to use petsc in fortran programs, can I build petsc
without fortran and thus avoid this situation?
Michael.
On 07/09/2013 04:31 PM, Satish Balay wrote:
> For some reason this issue comes up with mpi.mod provided by intel
> mpi.
> We have a configure test for it - but looks like its not sufficient to
> catch this issue.
> satish
> On Tue, 9 Jul 2013, Matthew Knepley wrote:
>> On Tue, Jul 9, 2013 at 3:11 PM, Michael Povolotskyi <mpovolot at purdue.edu>wrote:
>>> Dear Petsc users and developers,
>>> I'm trying to build petsc with Intel compiler.
>> 1) First, ask yourself whether you really want to build with the Intel
>> compiler. Then ask again.
>> 2) Do you need Fortran? If not, turn it off --with-fc=0.
>> 3) If you want Fortran and Intel (and have a hatred of free time), try the
>> legacy build
>>     make all-legacy
>> 4) If this is still broken, send the new make.log
>>    Thanks,
>>      Matt
>>> The configuration process runs okay (I attach the log here),
>>> but I get an error when I build it:
>>> -- Configuring done
>>> -- Generating done
>>> -- Build files have been written to: /home/mpovolot/Code_intel/**
>>> libs/petsc/build-real/linux
>>> Scanning dependencies of target petscsys
>>> [  0%] [  0%] [  0%] Building CXX object CMakeFiles/petscsys.dir/src/**
>>> sys/info/verboseinfo.c.o
>>> Building Fortran object CMakeFiles/petscsys.dir/src/**
>>> sys/f90-mod/petscsysmod.F.o
>>> sys/totalview/tv_data_display.**c.o
>>> Building CXX object CMakeFiles/petscsys.dir/src/**sys/python/pythonsys.c.o
>>> Building CXX object CMakeFiles/petscsys.dir/src/**sys/logging/plog.c.o
>>> /home/mpovolot/Code_intel/**libs/petsc/build-real/src/sys/**
>>> f90-mod/petscsysmod.F:6.11:
>>>          use mpi
>>>             1
>>> Fatal Error: File 'mpi.mod' opened at (1) is not a GFORTRAN module file
>>> make[6]: *** [CMakeFiles/petscsys.dir/src/**sys/f90-mod/petscsysmod.F.o]
>>> Error 1
>>> make[6]: *** Waiting for unfinished jobs....
>>> make[5]: *** [CMakeFiles/petscsys.dir/all] Error 2
>>> make[4]: *** [all] Error 2
>>> make[3]: *** [ccmake] Error 2
>>> make[2]: *** [cmake] Error 2
>>> ****************************ERROR**************************************
>>>    Error during compile, check linux/conf/make.log
>>>    Send it and linux/conf/configure.log to petsc-maint at mcs.anl.gov
>>> I attach here the make.log
>>> What is strange to me that it has something to do with Gfortran, while I
>>> want to build everything with Intel.
>>> Thank you for help,
>>> Michael.
>>> Michael Povolotskyi, PhD
>>> Research Assistant Professor
>>> Network for Computational Nanotechnology
>>> 207 S Martin Jischke Drive
>>> Purdue University, DLR, room 441-10
>>> West Lafayette, Indiana 47907
>>> phone: +1-765-494-9396
>>> fax: +1-765-496-6026
