[petsc-users] compile petsc with intel compiler
Tue Jul 9 15:18:00 CDT 2013
On Tue, Jul 9, 2013 at 3:11 PM, Michael Povolotskyi <mpovolot at purdue.edu>wrote:
> Dear Petsc users and developers,
> I'm trying to build petsc with Intel compiler.
1) First, ask yourself whether you really want to build with the Intel
compiler. Then ask again.
2) Do you need Fortran? If not, turn it off --with-fc=0.
3) If you want Fortran and Intel (and have a hatred of free time), try the
legacy build
   make all-legacy
4) If this is still broken, send the new make.log
    Matt
> The configuration process runs okay (I attach the log here),
> but I get an error when I build it:
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/mpovolot/Code_intel/**
> libs/petsc/build-real/linux
> Scanning dependencies of target petscsys
> [  0%] [  0%] [  0%] Building CXX object CMakeFiles/petscsys.dir/src/**
> sys/info/verboseinfo.c.o
> Building Fortran object CMakeFiles/petscsys.dir/src/**
> sys/f90-mod/petscsysmod.F.o
> sys/totalview/tv_data_display.**c.o
> Building CXX object CMakeFiles/petscsys.dir/src/**sys/python/pythonsys.c.o
> Building CXX object CMakeFiles/petscsys.dir/src/**sys/logging/plog.c.o
> /home/mpovolot/Code_intel/**libs/petsc/build-real/src/sys/**
> f90-mod/petscsysmod.F:6.11:
>         use mpi
>            1
> Fatal Error: File 'mpi.mod' opened at (1) is not a GFORTRAN module file
> make[6]: *** [CMakeFiles/petscsys.dir/src/**sys/f90-mod/petscsysmod.F.o]
> Error 1
> make[6]: *** Waiting for unfinished jobs....
> make[5]: *** [CMakeFiles/petscsys.dir/all] Error 2
> make[4]: *** [all] Error 2
> make[3]: *** [ccmake] Error 2
> make[2]: *** [cmake] Error 2
> ****************************ERROR**************************************
>   Error during compile, check linux/conf/make.log
>   Send it and linux/conf/configure.log to petsc-maint at mcs.anl.gov
> I attach here the make.log
> What is strange to me that it has something to do with Gfortran, while I
> want to build everything with Intel.
> Thank you for help,
> Michael.
> Michael Povolotskyi, PhD
> Research Assistant Professor
> Network for Computational Nanotechnology
> 207 S Martin Jischke Drive
> Purdue University, DLR, room 441-10
> West Lafayette, Indiana 47907
> phone: +1-765-494-9396
> fax: +1-765-496-6026
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130709/b2257bb2/attachment.html>
