[petsc-users] ERROR: Argument out of range!; Local index XX too large XX (max) at 0! with MatSetValuesStencil
Bishesh Khanal bisheshkh at gmail.com
Thu Jul 4 08:11:39 CDT 2013
On Thu, Jul 4, 2013 at 2:59 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jul 4, 2013 at 7:32 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> Hi all,
>> I'm trying to use DMCreateMatrix and MatStencil to fill up a matrix that
>> results from a finite difference discretization of a PDE (objective is to
>> solve the resulting linear system in the form of Ax=b).
>> However there are some errors and I'm not sure about the issue!
>> A short demo:
>> A 2D mXn grid, with two variables at each node (dof=2),
>> so the resulting A would be 2mn X 2mn.
>> Let's say the two variables are vx and vy, and the two associated
>> equations discretized are x-eq and y-eq.
>> Here is the relevant part of the code: (mat1 variable for the A matrix):
> Just sending the whole code is better. I suspect the logic is wrong for
> selecting the boundary.
>    Matt
Thanks, here is the complete code:
#include <petscsys.h>
#include <petscdmda.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
    PetscErrorCode ierr;
    DM             da;
    PetscInt       m=10,n=10;
    ierr = PetscInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);
    /* Create a DMDA and an associated vector */
    ierr = DMDACreate2d(PETSC_COMM_WORLD, DMDA_BOUNDARY_NONE,
DMDA_BOUNDARY_NONE,DMDA_STENCIL_BOX,m,n,
PETSC_DECIDE,PETSC_DECIDE,2,1,NULL,NULL,&da);CHKERRQ(ierr);
    Mat mat1;
    ierr = DMCreateMatrix(da,MATMPIAIJ,&mat1); CHKERRQ(ierr);
    MatStencil row, col[4]; //let's test 4 non-zeros in one row.
    PetscScalar val[4];
    PetscScalar coeff = 2.; //just a constant coefficient for testing.
    PetscInt i,j;
    DMDALocalInfo info;
    ierr = DMDAGetLocalInfo(da,&info); CHKERRQ(ierr);
    for(i = info.ys; i < info.ys+info.ym; ++i){
        for(j = info.xs; j < info.xs+info.xm; ++j){
            row.i = i;  row.j = j;   //one node at a time
            if (j == 0 || j == info.mx-1){ //left and right borders
                //vx(i,j) = 0;
                row.c = 0;
                col[0].c = 0;   val[0] = 1;
                col[0].i = i;   col[0].j = j;
                ierr =
MatSetValuesStencil(mat1,1,&row,1,col,val,INSERT_VALUES);CHKERRQ(ierr);
                //vy: //vy(i,j) - c*vy(i,j+-1) = 0;
                row.c = 1;
                col[0].c = 1;   val[1] = coeff;
                col[1].c = 1;
                col[1].i = i;
                if(j == 0) //vy(i,j) - c*vy(i,j+1) = 0;
                    col[1].j = j+1;
                else //vy(i,j) - c*vy(i,j-1) = 0;
                    col[1].j = j-1;
                ierr =
MatSetValuesStencil(mat1,1,&row,2,col,val,INSERT_VALUES);CHKERRQ(ierr);
            else if (i == 0 || i == info.my-1){  //top and bottom borders
                //vx: vx(i,j) - c* vx(i+-1,j) = 0;
                row.c = 0;
                col[1].c = 0;   val[1] = coeff;
                if (i == 0) //vx(i,j) - c*vx(i+1,j) = 0;
                    col[1].i = i+1;
                else //vx(i,j) - c*vx(i-1,j) = 0;
                    col[1].i = i-1;
                col[1].j = j;
                ierr =
                //vy(i,j) = 0;
                row.c = 1;
                col[0].c = 1;
                ierr =
            else { //Interior points:
                row.c = 0;//x-eq
                col[0].c = 0;   val[0] = 2*coeff;
                col[0].i = i;   col[0].j = j+1;
                col[1].c = 0;   val[1] = -val[0] - coeff;
                col[1].i = i;   col[1].j = j;
                col[2].c = 1;   val[2] = 4*coeff;
                col[2].i = i+1; col[2].j = j;
                col[3].c = 1;   val[3] = 4*coeff;
                col[3].i = i;   col[3].j = j;
                ierr =
MatSetValuesStencil(mat1,1,&row,4,col,val,INSERT_VALUES);CHKERRQ(ierr);
                row.c = 1; //y-eq
                col[0].c = 1;   val[0] = 2*coeff;
                col[1].c = 1;   val[1] = -val[0] - coeff;
                col[2].c = 0;   val[2] = 4*coeff;
                col[3].c = 0;   val[3] = 4*coeff;
                ierr =
    MatAssemblyBegin(mat1,MAT_FINAL_ASSEMBLY);
    MatAssemblyEnd(mat1,MAT_FINAL_ASSEMBLY);
    ierr =
MatSetOption(mat1,MAT_NEW_NONZERO_LOCATION_ERR,PETSC_TRUE);CHKERRQ(ierr);
    ierr = PetscObjectSetName((PetscObject)mat1,"mat1");CHKERRQ(ierr);
    /* clean up and exit */
    ierr = DMDestroy(&da);CHKERRQ(ierr);
    ierr = MatDestroy(&mat1);
    ierr = PetscFinalize();
    return 0;
>>     PetscInt m = 10, n=10;
>>     Mat mat1;
>>     PetscScalar val[4];
>>     PetscInt i,j;
>>     DMDALocalInfo info;
>> //Now fill up the matrix:
>>                 //vx(i,j) = 0;
>>                 row.c = 0;
>>                 ierr =
>>                 row.c = 1;
>>                 col[1].c = 1;
>>                 col[1].i = i;
>>                     col[1].j = j+1;
>>                     col[1].j = j-1;
>>                 ierr =
>>                 row.c = 0;
>>                     col[1].i = i+1;
>>                     col[1].i = i-1;
>>                 col[1].j = j;
>>                 ierr =
>>                 //vy(i,j) = 0;
>>                 row.c = 1;
>>                 col[0].c = 1;
>>                 ierr =
>>                 row.c = 0;//x-eq
>>                 ierr =
>>                 row.c = 1; //y-eq
>>                 ierr =
>> However I get the following error when run with 2 processors.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range!
>> [0]PETSC ERROR: Local index 120 too large 120 (max) at 0!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 3.4.1, Jun, 10, 2013
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: examples/FDdmda_test on a arch-linux2-cxx-debug named
>> edwards by bkhanal Thu Jul  4 14:20:11 2013
>> [0]PETSC ERROR: Libraries linked from
>> /home/bkhanal/Documents/softwares/petsc-3.4.1/arch-linux2-cxx-debug/lib
>> [0]PETSC ERROR: Configure run at Wed Jun 19 11:04:51 2013
>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
>> --with-cxx=g++ --download-f-blas-lapack=1 --download-mpich=1
>> -with-clanguage=cxx --download-hypre=1
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ISLocalToGlobalMappingApply() line 444 in
>> /home/bkhanal/Documents/softwares/petsc-3.4.1/src/vec/is/utils/isltog.c
>> [0]PETSC ERROR: MatSetValuesLocal() line 1967 in
>> /home/bkhanal/Documents/softwares/petsc-3.4.1/src/mat/interface/matrix.c
>> [0]PETSC ERROR: MatSetValuesStencil() line 1339 in
>> [0]PETSC ERROR: main() line 75 in
>> "unknowndirectory/"/user/bkhanal/home/works/cmake_tuts/petsc_test/examples/FDdmda_test.cxx
>> application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
>> [cli_0]: aborting job:
>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>> =   EXIT CODE: 63
>> =   CLEANING UP REMAINING PROCESSES
>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>> I do not understand how the index (i,j) are out of range when set to
>> corresponding fields in row and col variables. What could be the possible
>> problem ? And any suggestions on the way to debug this sort of issues ?
>> Thanks,
>> Bishesh
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130704/58991486/attachment.html>
