[petsc-users] automatic determination of which libraries petsc wants
Geoffrey Irving irving at naml.us
Thu Jan 31 18:46:53 CST 2013
On Thu, Jan 31, 2013 at 4:38 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 31, 2013 at 7:34 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jan 31, 2013 at 7:25 PM, Geoffrey Irving <irving at naml.us> wrote:
>>> We have an scons build system linking against PETSc, and it would be
>>> nice to have an automatic way of determining the list of libraries
>>> that a statically linked, installed version of PETSc wants (e.g., the
>>> MacPorts installed version).  What's a good way to do such a thing
>>> from *outside* the PETSc build system?
>> It depends on how much work you want to do. For at least two years I
>> think,
>> our default had been -lpetsc. I would just do this.
> Satish is right, use 'make getlinklibs'.
> However, if you don't have to waste time on a life or family, you may want
> to consider
> getting the info straight from the configure. You can load up the Python
> module from
> from $PETSC_ARCH/conf/RDict.db and pull out all these things. There is an
> example
> in configVars.py.
configVars.py errors out at "import script":
> ./bin/configVars.py
Traceback (most recent call last):
  File "./bin/configVars.py", line 7, in <module>
    import script
ImportError: No module named script
Indeed, I don't see any file named script.py anywhere underneath
/optlocal/lib/petsc, nor any directory named exactly "config" as
configVars seems to want.
Bad macports, bad?
Geoffrey
