[petsc-users] dense matrix problem
Alex Salazar alejandrocof at gmail.com
Thu Jan 31 11:34:04 CST 2013
Thanks Matthew !,  It sound very interesting I going to check it.
Regard Alex...
2013/1/31 Matthew Knepley <knepley at gmail.com>
> On Thu, Jan 31, 2013 at 11:07 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> "result is incorrect" is not helpful. Please include diagnostics. Are you
>> using an iterative or direct solver? Start here if you don't know what to
>> check:
>> http://scicomp.stackexchange.com/questions/513/why-is-my-iterative-linear-solver-not-converging
> And ASM works great for these problems:
>    http://arxiv.org/abs/0909.5413
>        Matt
>> On Thu, Jan 31, 2013 at 9:58 AM, Alex Salazar <alejandrocof at gmail.com>wrote:
>>> Hello, everyone
>>> I want to get the solution of algrebraic system (with a  dense
>>> zero-diagonal simetric matrix) of a interpolation problem (using radial
>>> basis functions) with Petsc.
>>>  For a few points (around 10 elements) using KSP I get the correct
>>> solution,  however when  I increase the number of points,  the result is
>>> incorrect.
>>> Any Idea ?
>>> Regards Alejandro.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130131/f147d87e/attachment-0001.html>
