[petsc-users] how does the srand48/drand48 works in windows build PETSc-3.3?
Yonghui lyh03259.aps at gmail.com
Tue Jan 29 23:47:04 CST 2013
OK. I saw the log file and figured my problem. I should remove rand48.c from
the source.
I agree that srand48 shouldn't be used for windows build.
Thanks for attach the log file. Everything is OK now.
-----Original Message-----
Sent: Tuesday, January 29, 2013 11:08 PM
To: Yonghui
Cc: 'PETSc users list'
Subject: RE: [petsc-users] how does the srand48/drand48 works in windows
build PETSc-3.3?
Perhaps you have the flag PETSC_HAVE_DRAND48 enabled [which shouldn't be for
MS compilers]
The logfiles get deleted/recreatd everynight in that location. You can try:
ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013-Jan-29/make_arch-ms
win_ps3.log
Satish
On Tue, 29 Jan 2013, Yonghui wrote:
> I created a Solution (2 projects: Fortran and c) for PETSc-3.3 and
> spent 2 afternoon for building the library purely with MSVS 2010 and
> parallel studio 13. The library works OK with ex19 as a test. Adding
> PETSC_HAVE_RAND into petscconf.h didn't solve my problem since srand48
> and drand48 are not replaced by rand. It seems PETSc just provides a
> wrapper for srand48 and no algorithms depend on them. So I think it
> should be OK as long as I don't use the wrapper.
> Thanks Satish's explanation but I can't reach the log (maybe not open
> to public?). Could you attach it, Satish?
> Yonghui
> From: petsc-users-bounces at mcs.anl.gov
> [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Tuesday, January 29, 2013 1:55 PM
> To: PETSc users list
> Subject: Re: [petsc-users] how does the srand48/drand48 works in
> cygwin is required primarily for the build tools. But compilation is
> done directly with MS compiler/s [so no cygwin.dll is used]
> wrt rand stuff - cl supports PETSC_HAVE_RAND. For eg: you can check
> all the flags that get set for MS compiler/[Comapq DVF] at:
> ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/build_arch-mswin_ps3.log
> Satish
> > Dear PETSc users,
> > I am start to use PETSc-3.3 and trying to build a Cygwin free
> > windows version (I just don't want to have Cygwin installed).
> > Thanks for the effort that the developers made for those macros
> > (PETSC_HAVE__FINITE, PETSC_HAVE__ISNAN, etc).
> > Here is a question: how does srand48/drand48 works in windows? Can I
> > replace them with other random number generator (that's the last
> > option since I am not sure whether they will be used in other
> > functions)? I don't see any equivalent definition in any headers in
> windows so far.
> > There is a windows build tutorial but need Cygwin installed. Does
> > that mean I have to use srand48/drand48 provided by Cygwin (not sure
> > but
> maybe)?
> > I am using MSVS 2010+intel compiler+mpich.
> > Any comment will be appreciated.
> > Thanks,
> > Yonghui
