[petsc-users] newbie questions on preconditioner LU
Mon Jan 28 13:33:26 CST 2013
On Mon, Jan 28, 2013 at 1:27 PM, Ling Zou <lingzou80 at gmail.com> wrote:
> Ahh.. that's true!
> In case M is not A (as you pointed out earlier), does PCLU provide the
> approximated inverse matrix of M^{-1} using LU factorization on M?
Not really, preconditioners are based on inexact algorithms applied to A,
not explicit formation of an M that is easier to factor exactly. Since the
preconditioner P ("=M^{-1}") is non-singular, there _exists_ an M such that
P=M^{-1}, but M is not explicitly computed and it's not used in the solve.
Only P is used, and only in special cases (like incomplete factorization)
is there even a practical algorithm available to compute M if you wanted
to. (For many interesting algorithms, M is dense even though A is sparse.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130128/d773efe7/attachment.html>
