[petsc-users] newbie questions on preconditioner LU
Mon Jan 28 13:29:16 CST 2013
On Mon, Jan 28, 2013 at 2:27 PM, Ling Zou <lingzou80 at gmail.com> wrote:
> On Mon, Jan 28, 2013 at 12:01 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Mon, Jan 28, 2013 at 1:39 PM, Ling Zou <lingzou80 at gmail.com> wrote:
>>> Hi, All
>>> I am trying to understand how the preconditioner works when using KSP.
>>> For example, when using KSP to solve the linear system problem,
>>> Ax = b
>>> with the default left preconditioning. We actually solve,
>>> M^(-1) * A x = M^(-1) * b
>>> where, M is the preconditioning matrix and in many cases, we just use A
>>> as the preconditioning matrix.
>>> Question:
>>> 1), Is the understanding above correct?
>> This is too simplistic. If you really mean M^{-1}, then no, you (almost)
>> never use A as M. If you mean an
>> approximate inverse to M, then yes.
>>> 2), If the understanding above is correct, is it correct to state the
>>> different methods provided in PETSc (such as PCLU, PCILU, etc) are to
>>> calculate the inverse matrix M^(-1) from M?
>>  An approximate inverse.
>>> 3), How to understand this sentence in the manual (PETSc Users Manual,
>>> Reversion 3.3, page 78, under 4.4 Preconditioners)
>>> "The direct preconditioner, PCLU, is, in fact, a direct solver for the
>>> linear system that uses LU factorization. PCLU is included as a
>>> preconditioner so that PETSc has a consistent interface among direct and
>>> iterative linear solvers."
>>> Does this indicate when using PCLU, we solve Ax = b directly using LU
>>> factorization, or, we solve M^(-1) from M using LU factorization?
>> Same thing, if M = A,
>>   M^{-1} A x = A^{-1} A x = x = A^{-1} b
>> which is Gaussian elimination for the original problem.
> Ahh.. that's true!
> In case M is not A (as you pointed out earlier), does PCLU provide the
> approximated inverse matrix of M^{-1} using LU factorization on M?
Yes.
   Matt
>>    Matt
>>> As a beginner to the PETSc, all questions are probably too simple. I'd
>>> appreciate it if someone could answer my questions.
>>> Best,
>>> Ling
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130128/1fbd2cbd/attachment-0001.html>
