[petsc-users] A little help for running config
Thu Jan 24 15:42:41 CST 2013
send configure.log to petsc-maint
Satish
On Thu, 24 Jan 2013, Yonghui wrote:
> Dear PETSc users,
> I am trying to compile PETSc, but there seems to be some problems when I run
> config.
> Here is my config command: ./config --prefix=/opt/PETSc --with-c++-support=1
> --with-c-support=1 --with-fortran=1 --with-mpi-dir=/opt/mpich2
> And here is the error message:
> TESTING: checkCLibraries from
> config.compilers(/home/biu/Projects/petsc-3.3-p5/config/BuildSystem/c
> onfig/compilers.py:161)
>                     UNABLE to EXECUTE BINARIES for ./configure
> Cannot run executables created with FC. If this machine uses a batch system
> to submit jobs you will need to configure using ./configure with the
> additional option  --with-batch.
> Otherwise there is problem with the compilers. Can you compile and run code
> with your C/C++ (and maybe Fortran) compilers?
> I just installed intel compiler on the machine this morning without any
> error. Then I compiled mpich2 (details below) with the intel compiler.
> Then sudo make install in /opt/mpich2. There is no error when compiling
> mpich2.
> More details:
> OS: Ubuntu 12.04 LTS (32-bit).
> CPU: Intel® Core? i7-2630QM CPU @ 2.00GHz × 4
> RAM: 2GB
> Compiler: icc (ICC) 13.0.1 20121010, ifort (IFORT) 13.0.1 20121010 (Parallel
> studio 2013 update1).
> MPICH2: 1.4.1p1 (compiled with compilers above without error).
> Any suggestion will be appreciated.
> Thanks,
> Yonghui
