[petsc-users] parallel Mat Mult a serial Vec or a serial Mat
Hui Zhang mike.hui.zhang at hotmail.com
Sun Jan 20 13:06:53 CST 2013
On Jan 20, 2013, at 7:41 PM, Jed Brown wrote:
> On Sun, Jan 20, 2013 at 12:26 PM, Hui Zhang <mike.hui.zhang at hotmail.com> wrote:
> I think about the method and find it is not as convenient as allowing inter-communicator operations.
> Supporting general mixed-communicator operations is a non-starter because the semantics can be ambiguous, it's very easy to get deadlock, and you can't debug or check invariants.
> Also note that inter-communicators require MPI-2 and have historically had implementation bugs since they are not heavily used.
> For example, VecScatter actually allows the two Vec in different communicators (or one must include
> the other?).
> I have more questions.
> (1) Does MatScatter supports MatMatMult?
> No, and VecScatter does not keep enough information to support such an operation. If you have the index sets, you can MatPermute(), but moving matrix entries around is quite expensive so you should usually avoid it.
> (2) Does MatConvert works on MATNEST?
> No, the implementation was never quite finished. We still think it's a useful thing.
> (3) Does MatGetLocalSubMat support localization to a sub-communicator instead of a process?
> No, you might be misunderstanding the purpose MatGetLocalSubMatrix(). It always returns a Mat object, but the communicator is not specified and it may not be "functional" in the sense of supporting MatMult, etc. It does, however, support MatSetValuesLocal() and related operations. See snes/examples/tutorials/ex28.c for an example of assembling a partitioned system into nested versus monolithic format without any knowledge of the representation.
Thanks very much! I am taking a look of this example.  But MATNEST does not support factorization.
I understand now I must do it in a basic way using MatSetValuesLocal.
