[petsc-users] make dist + hg
Sean Farley sean.michael.farley at gmail.com
Tue Jan 15 15:59:04 CST 2013
On Tue, Jan 15, 2013 at 3:49 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 15 Jan 2013, Jed Brown wrote:
>> On Tue, Jan 15, 2013 at 3:40 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > Why not commit your changes, and always do 'hg pull --rebase' to get
>> > latest petsc-dev stuff?
>> > Also - for uncommited stuff - I would get a patchfile with 'hg diff'
>> > and apply it to the remote source tree.
>> I would keep an hg clone on each machine. Then you can push and pull your
>> changes. I'd put all your changes in a bookmark that you can rebase. Note
>> that when you rebase, you'll get new commits when you pull from one of the
>> other machines, and you should get rid of the old patches.
> How does one get rid of the 'old patches' in this workflow?
If you want to see how mercurial will (automatically) handle this in
the future, you can install a dev version of mercurial and this
extension:
https://bitbucket.org/marmoute/mutable-history/
Then `hg rebase` will just mark the old commits as obsolete and the
pushing / pulling to the other clones will propagate the obsolete
markers. When Bitbucket fixes this issue:
https://bitbucket.org/site/master/issue/4560/provide-a-method-for-setting-the-phase-of
it'd be possible to use that workflow in the wild.
