[petsc-users] Mat Error
Thu Jan 10 13:10:15 CST 2013
* You MUST now call MatXXXSetPreallocation() or MatSetUp() on any matrix
you create directly (not using DMCreateMatrix()) before calling
MatSetValues(), MatSetValuesBlocked() etc.
http://www.mcs.anl.gov/petsc/documentation/changes/33.html
On Thu, Jan 10, 2013 at 1:08 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> Hello,
>           I am seeing an error in my code when i switched from pets 3.2-p5
> to petsc 3.3-p5. Please have a look at the error information below. I do
> not pass any petsc specific  command line options.
> The following is the subroutine which leads to error message.
>   subroutine initBCSolver_solver(this,comm,SolverType,NumDof,ierr,EqnCtx)
>     use SolverUtils_m
>     implicit none
> #include "finclude/petsc.h"
>     class(Solver_t), intent(inout) :: this
>     MPI_Comm            :: comm
>     integer, intent(in) :: SolverType
>     integer, intent(in) :: NumDof
>     class(*),pointer,intent(inout),optional :: EqnCtx
>     PetscErrorCode :: ierr
>     PetscReal :: rtol
>     PetscReal :: abstol
>     PetscReal :: dtol
>     PetscInt  :: maxits
>     ! Local Variables
>     PetscInt :: psize ! problem size
>     PetscScalar :: pfive !
>     ! Set solver type
>     !if(SolverType /= LINEAR .and. SolverType /= NonLinear) then
>     !  print*,'Error:: Solver must be linear or Nonlinear',solverType
>     !  stop
>     !end if
>     this%comm = comm
>     this%SolverType = SolverType
>     ! Set problem size
>     this%numDof = numDof
>     psize = this%numDof ! 3
>     ! intiate Storage vectors
>     call VecCreateSeq(this%comm,psize,this%sol,ierr)
>     call VecSetOption(this%sol,
> VEC_IGNORE_NEGATIVE_INDICES,PETSC_TRUE,ierr)
>     call VecDuplicate(this%sol,this%fxn,ierr)
>     this%flag_vec_sol = .true.
>     this%flag_vec_fxn = .true.
>     select case(this%SolverType)
>       case(Linear)
>         ! create the linear operator
>         call MatCreate(this%comm,this%A,ierr)
>         call MatSetSizes(this%A,PETSC_DECIDE,PETSC_DECIDE,psize,psize,ierr)
>         call MatSetFromOptions(this%A,ierr)
>         ! create storage for rhs
>         call VecDuplicate(this%sol,this%rhs,ierr)
>         ! Create KSP context
>         call KSPCreate(this%comm,this%ksp,ierr)
>         this%flag_ksp_ksp = .true.
>         rtol = PETSC_DEFAULT_DOUBLE_PRECISION
>         abstol = PETSC_DEFAULT_DOUBLE_PRECISION
>         dtol = PETSC_DEFAULT_DOUBLE_PRECISION
>         maxIts = PETSC_DEFAULT_INTEGER
>         call KSPSetTolerances(this%ksp,rtol,abstol,dtol,maxIts,ierr);
>         call KSPSetFromOptions(this%ksp,ierr)
>         call
> KSPSetOperators(this%ksp,this%A,this%A,DIFFERENT_NONZERO_PATTERN,ierr)
>       case(nonLinear)
>         call MatCreate(this%comm,this%Jac,ierr)
>         this%flag_mat_Jac = .true.
>         call
> MatSetSizes(this%Jac,PETSC_DECIDE,PETSC_DECIDE,psize,psize,ierr)
>         call MatSetFromOptions(this%Jac,ierr)
>         !  create snes context
>         call SNESCreate(this%comm,this%snes,ierr)
>         this%flag_snes_snes = .true.
>         !  Set function evaluation routine and vector
>         ! use the defualt FormFunction_snes
>         call
> SNESSetFunction(this%snes,this%fxn,FormFunction_snes,this,ierr)
>         !  Set Jacobian matrix data structure and Jacobian evaluation
> routine
>         call
> SNESSetJacobian(this%snes,this%Jac,this%Jac,FormJacobian_snes,this,ierr)
>         !call
> SNESSetJacobian(this%snes,this%Jac,this%Jac,PETSC_NULL_FUNCTION,PETSC_NULL_OBJECT,ierr)
>         call
> SNESSetTolerances(this%snes,1e-15*25.6E-3,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_DOUBLE_PRECISION,25000,100000,ierr);
>         call SNESSetFromOptions(this%snes,ierr)
>     end select
>     !call VecDuplicate(this%sol,this%bOhmic,ierr)
>     pfive = 0.0
>     call VecSet(this%sol,pfive,ierr) ! set Intial Guess
>   end subroutine initBCSolver_solver
> end module BoundaryConditionUtils_m
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> argument 1 "mat" before MatGetFactorAvailable()!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 5, Sat Dec  1 15:10:41
> CST 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR:
> /home1/00924/Reddy135/projects/utgds/test/IIIVTunnelFET2D/PoisTest on a
> sandybrid named login2.stampede.tacc.utexas.edu by Reddy135 Thu Jan 10
> 12:50:19 2013
> [0]PETSC ERROR: Libraries linked from
> /opt/apps/intel13/mvapich2_1_9/petsc/3.3/sandybridge-debug/lib
> [0]PETSC ERROR: Configure run at Mon Jan  7 14:42:13 2013
> [0]PETSC ERROR: Configure options --with-x=0 -with-pic
> --with-external-packages-dir=/opt/apps/intel13/mvapich2_1_9/petsc/3.3/externalpackages
> --with-mpi-compilers=1 --with-mpi-dir=/opt/apps/intel13/mvapich2/1.9
> --with-scalar-type=real --with-dynamic-loading=0 --with-shared-libraries=1
> --with-spai=1 --download-spai --with-hypre=1 --download-hypre
> --with-mumps=1 --download-mumps --with-scalapack=1 --download-scalapack
> --with-blacs=1 --download-blacs --with-spooles=1 --download-spooles
> --with-superlu=1 --download-superlu --with-superlu_dist=1
> --download-superlu_dist --with-parmetis=1 --download-parmetis
> --with-metis=1 --download-metis --with-debugging=yes
> --with-blas-lapack-dir=/opt/apps/intel/13/composer_xe_2013.1.117/mkl/lib/intel64
> --with-mpiexec=mpirun_rsh --COPTFLAGS= --CXXOPTFLAGS= --FOPTFLAGS=
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatGetFactorAvailable() line 3921 in
> /opt/apps/intel13/mvapich2_1_9/petsc/3.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: PCGetDefaultType_Private() line 26 in
> /opt/apps/intel13/mvapich2_1_9/petsc/3.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: PCSetFromOptions() line 181 in
> /opt/apps/intel13/mvapich2_1_9/petsc/3.3/src/ksp/pc/interface/pcset.c
> [0]PETSC ERROR: KSPSetFromOptions() line 287 in
> /opt/apps/intel13/mvapich2_1_9/petsc/3.3/src/ksp/ksp/interface/itcl.c
> [0]PETSC ERROR: SNESSetFromOptions() line 678 in
> /opt/apps/intel13/mvapich2_1_9/petsc/3.3/src/snes/interface/snes.c
> Dharmendar Reddy Palle
> Graduate Student
> Microelectronics Research center,
> University of Texas at Austin,
> 10100 Burnet Road, Bldg. 160
> MER 2.608F, TX 78758-4445
> e-mail: dharmareddy84 at gmail.com
> Phone: +1-512-350-9082
> United States of America.
> Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130110/b9c16abc/attachment-0001.html>
