[petsc-users] Dealing with 2nd Derivatives on Boundaries
David Scott d.scott at ed.ac.uk
Thu Jan 10 09:03:14 CST 2013
Hello,
I am solving Poisson's equation (actually Laplace's equation in this
simple test case) on a 3D structured grid. The boundary condition in the
first dimension is periodic. In the others there are Von Neumann
conditions except for one surface where the second derivative is zero. I
have specified DMDA_BOUNDARY_NONE in these two dimensions and deal with
the boundary conditions by constructing an appropriate matrix. Here is
an extract from the Fortran code:
               if (j==0) then
                 ! Von Neumann boundary conditions on y=0 boundary.
                 v(1) = 1
                   col(MatStencil_i, 1) = i
                   col(MatStencil_j, 1) = j
                   col(MatStencil_k, 1) = k
                 v(2) = -1
                   col(MatStencil_i, 2) = i
                   col(MatStencil_j, 2) = j+1
                   col(MatStencil_k, 2) = k
                 call MatSetValuesStencil(B, 1, row, 2, col, v,
INSERT_VALUES, ierr)
               else if (j==maxl) then
                 ! Boundary condition on y=maxl boundary.
                 v(1) = 1
                 v(2) = -2
                   col(MatStencil_j, 2) = j-1
                 v(3) = 1
                   col(MatStencil_i, 3) = i
                   col(MatStencil_j, 3) = j-2
                   col(MatStencil_k, 3) = k
                 call MatSetValuesStencil(B, 1, row, 3, col, v,
               else if (k==0) then
Here the second clause deals with the second derivative on the boundary.
In order for this code to work I have to set the stencil width to 2 even
though 'j-2' refers to an interior, non-halo
point in the grid. This leads to larger halo swaps than would be
required if a stencil width of 1 could be used.
Is there a better way to encode the problem?
David
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
