[petsc-users] Cholesky factorization
Petar Petrovic ppetrovic573 at gmail.com
Tue Jan 8 14:25:44 CST 2013
Thanks, but is there any way to check if the package is already installed?
My problem is that I run the PETSc installation someone already set up and
I don't have the access to change it. I have tried running ./configure
--help in the directory PETSc is installed, but it just reports the error
because I don't have the access permition.
Also, sorry I didn't understand, are the directives in the code enough or
do I have to run my mpiexec command with additional options?
On Tue, Jan 8, 2013 at 1:35 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 8, 2013 at 12:33 PM, Petar Petrovic <ppetrovic573 at gmail.com>wrote:
>> Thank you very much.
>> Can you tell me how to set the package that is used for
>> MatCholeskyFactor?
>> I need it to run for a sparse matrix so I have tried using:
>> #ifdef PETSC_HAVE_CHOLMOD
>> #endif
>> but the code inside doesn't run. Does this mean that the package is not
>> installed or am I supposed to do something else, use some command line
>> options or something? Sorry these are very basic questions, but I am new to
>> PETSc and I cannot seem to find examples for this.
> You need to activate 3rd party packages during configure, e.g.
> --download-umfpack.
> http://www.mcs.anl.gov/petsc/documentation/installation.html
>    Matt
>> On Tue, Jan 8, 2013 at 12:24 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>>>    Matt
>>> On Tue, Jan 8, 2013 at 11:21 AM, Petar Petrovic <ppetrovic573 at gmail.com>wrote:
>>>> Hello,
>>>> Can you please tell me for which type of matrices can I run Cholesky
>>>> factorization (MatCholeskyFactor) ? Can it be applied on sparse matrices,
>>>> e.g. MATAIJ ?
>>>> Many thanks
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130108/3f3145f9/attachment.html>
