[petsc-users] ML options
Mark F. Adams mark.adams at columbia.edu
Mon Jan 7 10:36:19 CST 2013
> ML isn't using eigenvalue estimation (doesn't expose the algorithm). Sanjay is using the default smoother (Richardson + SOR) rather than chebyshev/pbjacobi.
The only other problem that I can think of is that ML is not getting the null space correctly.  Unfortunately I do not see anything in MLs verbose output that says what it is doing for the null space.
It would be good to know if GAMG has the same problem.
