[petsc-users] A quick question on 'un-symmetric graph'
Mark F. Adams mark.adams at columbia.edu
Sat Jan 5 22:19:29 CST 2013
> This is a symmetric graph, but not a symmetric matrix, though the asymmetry is only due to boundary conditions (boundary rows have only a diagonal nonzero; the other zeros are still stored explicitly). Do you have a preference about how this is handled? (I don't think we should need extra options to handle this extremely common case.)
If the graph is symmetric then the only problem is that after thresholding the graph can be unsymmetric if the values are not symmetric.
So the solution is to:
[0]PETSC ERROR: Have un-symmetric graph (apparently). Use
'-pc_gamg_sym_graph true' to symetrize the graph or '-pc_gamg_threshold
0.0' if the matrix is structurally symmetric.!
There is no simple way to make fix this, that I can think of.  If I threshold I need to have the transpose data to threshold symmetrically and if the graph is not symmetric then the MIS algorithm would need to be reworked.   The best way that I can think of to rework MIS is to symmetrize the graph, which puts us back to where we started.
As the user noticed, this is not a problem is serial and it can often work in small scale parallel, but it gets you eventually.
symetrizing the graph is not that expensive (compared to the rest of setup) -- we could make '-pc_gamg_sym_graph true' the default … I'm thinking this is a good idea.  Better to be robust  and deal with optimizing for users that can not amortize setup.
