[petsc-users] DMPlexDistribute question
Yaakoub El Khamra yaakoub at tacc.utexas.edu
Tue Dec 31 11:59:19 CST 2013
Just sent credentials. I am also trying on stampede.
Regards
Yaakoub El Khamra
On Tue, Dec 31, 2013 at 11:44 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Dec 31, 2013 at 11:38 AM, Yaakoub El Khamra <
> yaakoub at tacc.utexas.edu> wrote:
>> snes ex12 also hangs. Then I started trying all other examples, all MPI
>> examples hang. Basic MPI code and benchmarks appear to compile and run
>> fine. I recompiled PETSc and went carefully over the output, there are a
>> lot of warnings (even from a stable build)
>> If I compile petsc with openmpi 1.7.3 and gcc 4.8.2 and the configure
>> line:
>> /configure --with-mpi-compilers=yes --download-metis --download-parmetis
>> --download-fiat --with-fortran=yes --download-scientificpython
>> --download-f-blas-lapack=1  --download-triangle --download-chaco
>> --download-exodusii --download-netcdf --download-hdf5
>> I get a lot of warnings from MPI that might significant. I can provide
>> access to the fedora 20 box where I am working.
> Either send login info to petsc-maint at mcs.anl.gov, or get a stack trace
> of the hang using gdb.
>   Thanks,
>     Matt
>> /home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:159:5: warning:
>> ‘MPI_Keyval_create’ is deprecated (declared at
>> /usr/include/openmpi-x86_64/mpi.h:1506): MPI_Keyval_create is superseded by
>> MPI_Comm_create_keyval in MPI-2.0 [-Wdeprecated-declarations]
>>      ierr =
>> MPI_Keyval_create(MPI_NULL_COPY_FN,Petsc_DelTmpShared,&Petsc_Tmp_keyval,0);CHKERRQ(ierr);
>> ‘OMPI_C_MPI_NULL_COPY_FN’ is deprecated (declared at
>> /usr/include/openmpi-x86_64/mpi.h:828): MPI_NULL_COPY_FN is deprecated in
>> /home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:162:3: warning:
>> ‘MPI_Attr_get’ is deprecated (declared at
>> /usr/include/openmpi-x86_64/mpi.h:1201): MPI_Attr_get is superseded by
>> MPI_Comm_get_attr in MPI-2.0 [-Wdeprecated-declarations]
>>    ierr =
>> MPI_Attr_get(comm,Petsc_Tmp_keyval,(void**)&tagvalp,(int*)&iflg);CHKERRQ(ierr);
>> /home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:168:5: warning:
>> ‘MPI_Attr_put’ is deprecated (declared at
>> /usr/include/openmpi-x86_64/mpi.h:1203): MPI_Attr_put is superseded by
>> MPI_Comm_set_attr in MPI-2.0 [-Wdeprecated-declarations]
>>      ierr = MPI_Attr_put(comm,Petsc_Tmp_keyval,tagvalp);CHKERRQ(ierr);
>> /home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c: In function
>> ‘PetscSharedWorkingDirectory’:
>> /home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:282:5: warning:
>>      ierr =
>> MPI_Keyval_create(MPI_NULL_COPY_FN,Petsc_DelTmpShared,&Petsc_WD_keyval,0);CHKERRQ(ierr);
>> /home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:285:3: warning:
>>    ierr =
>> MPI_Attr_get(comm,Petsc_WD_keyval,(void**)&tagvalp,(int*)&iflg);CHKERRQ(ierr);
>> /home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:291:5: warning:
>>      ierr = MPI_Attr_put(comm,Petsc_WD_keyval,tagvalp);CHKERRQ(ierr);
>> Regards
>> Yaakoub El Khamra
>> On Mon, Dec 30, 2013 at 10:58 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Mon, Dec 30, 2013 at 7:34 PM, Yaakoub El Khamra <
>>>> If I create a dm with DMPlexCreateBoxMesh and immediately attempt to
>>>> distribute it with DMPlexDistribute, the call to DMPlexDistribute never
>>>> returns. I am working with a development checkout and the code looks as
>>>> follows:
>>>>       call DMPlexCreateBoxMesh(PETSC_COMM_WORLD, 2, PETSC_TRUE, dm,
>>>>      $     ierr)
>>>>       CHKERRQ(ierr)
>>>>       call DMPlexDistribute(dm, "chaco", 0,
>>>>      $ PETSC_NULL_OBJECT, distributedMesh, ierr)
>>>>       CHKERRQ(ierr)
>>>> Any thoughts?
>>> Can you run SNES ex12? It does exactly this and gets run in the nightly
>>> tests. I can run it in parallel
>>> with no problems. My guess is that something is going wrong with the
>>> Fortran binding. Can you
>>> get a stack trace for the hang? If not, can you send a full Fortran
>>> program which exhibits your problem?
>>>    Matt
>>>> Regards
>>>> Yaakoub El Khamra
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131231/a447ecc5/attachment.html>
