[petsc-users] DMPlexDistribute question
Yaakoub El Khamra yaakoub at tacc.utexas.edu
Tue Dec 31 11:38:09 CST 2013
snes ex12 also hangs. Then I started trying all other examples, all MPI
examples hang. Basic MPI code and benchmarks appear to compile and run
fine. I recompiled PETSc and went carefully over the output, there are a
lot of warnings (even from a stable build)
If I compile petsc with openmpi 1.7.3 and gcc 4.8.2 and the configure line:
/configure --with-mpi-compilers=yes --download-metis --download-parmetis
--download-fiat --with-fortran=yes --download-scientificpython
--download-f-blas-lapack=1  --download-triangle --download-chaco
--download-exodusii --download-netcdf --download-hdf5
I get a lot of warnings from MPI that might significant. I can provide
access to the fedora 20 box where I am working.
/home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:159:5: warning:
‘MPI_Keyval_create’ is deprecated (declared at
/usr/include/openmpi-x86_64/mpi.h:1506): MPI_Keyval_create is superseded by
MPI_Comm_create_keyval in MPI-2.0 [-Wdeprecated-declarations]
     ierr =
MPI_Keyval_create(MPI_NULL_COPY_FN,Petsc_DelTmpShared,&Petsc_Tmp_keyval,0);CHKERRQ(ierr);
‘OMPI_C_MPI_NULL_COPY_FN’ is deprecated (declared at
/usr/include/openmpi-x86_64/mpi.h:828): MPI_NULL_COPY_FN is deprecated in
/home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:162:3: warning:
‘MPI_Attr_get’ is deprecated (declared at
/usr/include/openmpi-x86_64/mpi.h:1201): MPI_Attr_get is superseded by
MPI_Comm_get_attr in MPI-2.0 [-Wdeprecated-declarations]
   ierr =
MPI_Attr_get(comm,Petsc_Tmp_keyval,(void**)&tagvalp,(int*)&iflg);CHKERRQ(ierr);
/home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:168:5: warning:
‘MPI_Attr_put’ is deprecated (declared at
/usr/include/openmpi-x86_64/mpi.h:1203): MPI_Attr_put is superseded by
MPI_Comm_set_attr in MPI-2.0 [-Wdeprecated-declarations]
     ierr = MPI_Attr_put(comm,Petsc_Tmp_keyval,tagvalp);CHKERRQ(ierr);
/home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c: In function
‘PetscSharedWorkingDirectory’:
/home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:282:5: warning:
     ierr =
MPI_Keyval_create(MPI_NULL_COPY_FN,Petsc_DelTmpShared,&Petsc_WD_keyval,0);CHKERRQ(ierr);
/home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:285:3: warning:
   ierr =
MPI_Attr_get(comm,Petsc_WD_keyval,(void**)&tagvalp,(int*)&iflg);CHKERRQ(ierr);
/home/yye00/Work/Saswata/petsc/src/sys/fileio/fretrieve.c:291:5: warning:
     ierr = MPI_Attr_put(comm,Petsc_WD_keyval,tagvalp);CHKERRQ(ierr);
Regards
Yaakoub El Khamra
On Mon, Dec 30, 2013 at 10:58 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 30, 2013 at 7:34 PM, Yaakoub El Khamra <
> yaakoub at tacc.utexas.edu> wrote:
>> If I create a dm with DMPlexCreateBoxMesh and immediately attempt to
>> distribute it with DMPlexDistribute, the call to DMPlexDistribute never
>> returns. I am working with a development checkout and the code looks as
>> follows:
>>       call DMPlexCreateBoxMesh(PETSC_COMM_WORLD, 2, PETSC_TRUE, dm,
>>      $     ierr)
>>       CHKERRQ(ierr)
>>       call DMPlexDistribute(dm, "chaco", 0,
>>      $ PETSC_NULL_OBJECT, distributedMesh, ierr)
>>       CHKERRQ(ierr)
>> Any thoughts?
> Can you run SNES ex12? It does exactly this and gets run in the nightly
> tests. I can run it in parallel
> with no problems. My guess is that something is going wrong with the
> Fortran binding. Can you
> get a stack trace for the hang? If not, can you send a full Fortran
> program which exhibits your problem?
>    Matt
>> Regards
>> Yaakoub El Khamra
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131231/b3500c2b/attachment-0001.html>
