[petsc-users] DMRefine issue
Yaakoub El Khamra yaakoub at tacc.utexas.edu
Mon Dec 30 19:23:17 CST 2013
Greetings
I am try to use DMRefine to refine a dm I create with DMPlexCreateBoxMesh
with tonight's checkout. A quick glance at the DMView output from the DM's
shows that the refinedMesh looks a lot like the original
dm. DMGetRefineLevel returns 1 though. I must be missing something
elementary here. Can someone please confirm if there are any glaring
mistakes I made? Also if I want to refine and distribute, should I refine
on a single processor then distribute or can I refine a couple of times,
distribute, and refine some more?
The test code looks as follows:
      program testRefine
      implicit none
#include "finclude/petsc.h90"
      DM :: dm
      DM :: refinedMesh
      PetscInt :: r
      PetscInt :: dim
      PetscBool :: interpolate
      PetscErrorCode :: ierr
      call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
      CHKERRQ(ierr)
      dim = 2
      interpolate = PETSC_TRUE
!     Create a mesh
      call DMPlexCreateBoxMesh(PETSC_COMM_WORLD, dim, interpolate, dm,
     $     ierr)
      CHKERRQ(ierr)
      call DMView(dm, PETSC_VIEWER_STDOUT_WORLD, ierr)
      CHKERRQ(ierr)
      call DMRefine(dm, PETSC_COMM_WORLD, refinedMesh, ierr)
      CHKERRQ(ierr)
      call DMView(refinedMesh, PETSC_VIEWER_STDOUT_WORLD, ierr)
      CHKERRQ(ierr)
      call DMGetRefineLevel(refinedMesh, r, ierr)
      write (*,*) "The value of r is:", r
      call DMDestroy(dm, ierr)
      call DMDestroy(refinedMesh, ierr)
      CHKERRQ(ierr)
      call PetscFinalize(ierr)
      end program testRefine
And the output:
DM_0x1122bb0_0 in 2 dimensions:
  0-cells: 9
  1-cells: 16
  2-cells: 8
Labels:
  marker: 2 strata of sizes (16, 5)
  depth: 3 strata of sizes (9, 16, 8)
DM_0x1122bb0_1 in 2 dimensions:
  0-cells: 9
  1-cells: 16
  2-cells: 8
Labels:
  marker: 2 strata of sizes (16, 1)
 The value of r is:           1
Regards
Yaakoub El Khamra
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131230/fdccef70/attachment.html>
