[petsc-users] dmda and structures
Sun Dec 29 13:53:18 CST 2013
On Dec 29, 2013, at 1:38 PM, Gideon Simpson <gideon.simpson at icloud.com> wrote:
> How would that work?
   I’ve modified your code fragment below with how I think you could do it.
>  I took Jed's advice, and set it up so that I have access via:
> realization_array[ realization_dof * i + 1 +j] = jth point of ith realization
> and then I further used a pointer:
> PetscScalar *x;
> x = & realization_array[ realization_dof * i + 1];
> so that I have "clean" access to the elements of each realization through x[j].
> -gideon
> On Dec 29, 2013, at 2:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> DMDAVecGetArrayDOF() might serve your needs. You would access with realization_array[i][j]  for the ith grid point and j th realization
>>  Barry
>> On Dec 28, 2013, at 7:44 PM, Gideon Simpson <gideon.simpson at icloud.com> wrote:
>>> I'm trying to use 1D DMDA's to manage distributed monte carlo computations, and I've got the following problem.  If I know, in advance, how many floating points are needed for each realization, everything is fine.  But, if I want to be able to set this at run time, I can't get it to work.  What I have is:
>>> then, in the main part of the code:
>>> Realization *realization_array;
>>> DM sim_data_da;
>>> Vec sim_data_vec;
>>> PetscInt xsize=10, realization_dof, i;
>>> PetscOptionsGetInt(NULL, "-xsize", &xsize, NULL);
>>> realization_dof	  = xsize + 1;
>>> DMDACreate1d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE, batch_size, realization_dof, 0, NULL, &sim_data_da);
>>> DMCreateGlobalVector(sim_data_da,&sim_data_vec);
PetscScalar **realization_array;
>>> DMDAVecGetArrayDOF(sim_data_da, sim_data_vec, & realization_array);
    something = realization_array[i][j];     here i varies from xs to xs+xm-1  and j varies from 0 to realization_dof-1
>>> -gideon
