[petsc-users] fieldsplit error
subramanya sadasiva potaman at outlook.com
Fri Dec 27 23:15:00 CST 2013
I figured out that block size was missing. However I am not quite sure what the block size means.
--- Original Message ---
Sent: December 28, 2013 12:06 AM
To: "subramanya sadasiva" <potaman at outlook.com>
Cc: petsc-users at mcs.anl.gov, libmesh-users at lists.sourceforge.net
Subject: Re: [petsc-users] fieldsplit error
Add
-pc_fieldsplit_block_size 2
See example
petsc/src/snes/examples/tutorials/ex19.c:
./ex19 -snes_monitor_short -ksp_monitor_short -pc_type fieldsplit
-pc_fieldsplit_block_size 2 -pc_fieldsplit_0_fields 0,1
-pc_fieldsplit_1_fields 0,1 -pc_fieldsplit_type multiplicative -snes_view
-fieldsplit_pc_type lu -da_refine 1 -ksp_type fgmres
(see runex19_8 in petsc/src/snes/examples/tutorials/makefile)
Hong
On Fri, Dec 27, 2013 at 9:25 PM, subramanya sadasiva <potaman at outlook.com>wrote:
>  Hi,
> I have a nonlinear system with 6 variables grouped in two sets of 3. I am
> trying to get a fieldsplit preconditioner working . I have the following
> options set up
>  -pc_type fieldsplit
> -fieldsplit_0_fields 0,2,4
> -fieldsplit_1_fields 1,3,5
> -fieldsplit_0_ksp cg
> -fieldsplit_1_ksp cg
> -fieldsplit_0_pc hypre
> -fieldsplit_1_pc hypre
>  However, I get the following error. My installation of libmesh has block
> matrices disabled, which I've seen to cause problems with fieldsplit. Any
> ideas what might cause this error?
> Thanks,
> Subramanya
>  [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data!
> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 1!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.4.3, unknown
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131228/444a3afa/attachment.html>
