[petsc-users] Issue about matsetvalues when turn off debugging
Fri Dec 20 13:31:07 CST 2013
Gavin Ge <jianchaoge at gmail.com> writes:
> Thanks Jed. After configuring using this, how can I turn on the debugging option when I compile the code?
Compiling your code?  If you use the PETSc makefiles, the same flag will
be used.  If you don't use PETSc makefiles, you're on your own to set
compilation flags.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131220/5e47d046/attachment.pgp>
