[petsc-users] Problem with TS and PCMG
Torquil Macdonald Sørensen torquil at gmail.com
Wed Dec 18 04:14:57 CST 2013
Hi!
Just a second try in case the first email was unintentionally missed. In
short, I'm wondering if it is possible to use TSSolve without using any DM
structure:
When I was debugging my program I tried to analyse the difference between
the TSSolve-based time iteration program, and a version where I do the
time-stepping manually using a for-loop which repeateed KSPSolve functions.
The debugger showed that in the TSSolve program a pointer named
ts->snes->ksp->pc->dm was nonzero, but in the for-loop program it was zero.
In the TSSolve-program, and pc->dm != 0 made it enter a block of code
within PCSetUp_MG that called DMCoarsen, which then crashed. So I guess I'm
wondering how to tell PETSc that I'm not using any DM structure.
Best regards
Torquil Sørensen
On 14 December 2013 14:46, Torquil Macdonald Sørensen <torquil at gmail.com>wrote:
> Hi!
> I'm getting segfault problems when trying to use TSStep or TSSolve with
> TSBEULER and TSLINEAR, together with PCMG. So I have reduced my code to
> a minimal (and mathematically trivial) test case which displays the same
> error, and I'm hoping someone here will spot any errors that I've made
> in my setup of TS.
> I can use my PCMG restriction and interpolation matrices with success in
> a single linear solve with KSPSolve (and can see that MG is being used
> by adding -ksp_view), but for some reason I am not able to get PCMG
> working with TSStep. So I'm wondering if I'm forgetting a step when when
> I'm setting up the TS?
> My test case tries to solve Id*dU/dt = Id*U, where Id is a 5x5 identity
> matrix, and U is a 5-vector unknown, with initial condition U = 0. The
> PCMG construction uses an additional coarse grid of 3 points. The fine
> grid vertices are labelled 0, 1, 2, 3, 4, while the coarse grid is
> labelled 0, 1, 2, The coarse grid vertices coincide with the fine grid
> vertices 0, 2 and 4. The resulting interpolation and restriction
> matrices arise as interpolations matrices between the FEM spaces defined
> using piecewise linear shape functions on these grids.
> The GDB message I'm getting is:
> Program received signal SIGSEGV, Segmentation fault.
> 0x0000000000000000 in ?? ()
> (gdb) where
> #0  0x0000000000000000 in ?? ()
> #1  0x00007fa0e6bbd172 in DMCoarsen (dm=0x28e9170, comm=0x7fa0e638d9c0
> <ompi_mpi_comm_null>, dmc=0x295a490) at dm.c:1811
> #2  0x00007fa0e6ff1c1e in PCSetUp_MG (pc=0x28d71a0) at mg.c:593
> #3  0x00007fa0e72eb6ce in PCSetUp (pc=0x28d71a0) at precon.c:890
> #4  0x00007fa0e6e6f7e8 in KSPSetUp (ksp=0x28e1a50) at itfunc.c:278
> #5  0x00007fa0e6e70a30 in KSPSolve (ksp=0x28e1a50, b=0x297bea0,
> x=0x2981970) at itfunc.c:399
> #6  0x00007fa0e6e8ae0c in SNESSolve_KSPONLY (snes=0x28c7710) at
> ksponly.c:44
> #7  0x00007fa0e757b642 in SNESSolve (snes=0x28c7710, b=0x0, x=0x296c7d0)
> at snes.c:3636
> #8  0x00007fa0e76280cc in TSStep_Theta (ts=0x2894220) at theta.c:183
> #9  0x00007fa0e766a202 in TSStep (ts=0x2894220) at ts.c:2507
> #10 0x0000000000403363 in main (argc=3, argv=0x7fff08015378) at
> /home/tmac/research/schrodinger/source/testcase.cpp:97
> My testcase code is:
> #include "petscts.h"
> int main(int argc, char ** argv)
>     PetscErrorCode ierr = PetscInitialize(&argc, &argv, 0, 0);
> CHKERRQ(ierr);
>     int const nb_dof_fine = 5;
>     int const nb_dof_coarse = 3;
>     Vec x; // A vector to hold the solution on the fine grid
>     ierr = VecCreateSeq(PETSC_COMM_SELF, nb_dof_fine, &x); CHKERRQ(ierr);
>     Mat Id; // Identity matrix on the vector space of the fine grid
>     ierr = MatCreateSeqAIJ(PETSC_COMM_SELF, nb_dof_fine, nb_dof_fine, 1,
> 0, &Id); CHKERRQ(ierr);
>     for(int i = 0; i != nb_dof_fine; i++) { MatSetValue(Id, i, i, 1.0,
> INSERT_VALUES); }
>     ierr = MatAssemblyBegin(Id, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>     ierr = MatAssemblyEnd(Id, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>     ierr = MatView(Id, PETSC_VIEWER_STDOUT_SELF);
>     Mat interp; // Multigrid interpolation matrix
>     ierr = MatCreateSeqAIJ(PETSC_COMM_SELF, nb_dof_fine, nb_dof_coarse,
> 2, 0, &interp); CHKERRQ(ierr);
>     ierr = MatSetValue(interp, 0, 0, 1.0, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(interp, 1, 0, 0.5, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(interp, 1, 1, 0.5, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(interp, 2, 1, 1.0, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(interp, 3, 1, 0.5, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(interp, 3, 2, 0.5, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(interp, 4, 2, 1.0, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatAssemblyBegin(interp, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>     ierr = MatAssemblyEnd(interp, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>     ierr = MatView(interp, PETSC_VIEWER_STDOUT_SELF);
>     Mat restrict; // Multigrid restriction matrix, not the transpose of
> "interp"
>     ierr = MatCreateSeqAIJ(PETSC_COMM_SELF, nb_dof_coarse, nb_dof_fine,
> 1, 0, &restrict); CHKERRQ(ierr);
>     ierr = MatSetValue(restrict, 0, 0, 1.0, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(restrict, 1, 2, 1.0, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatSetValue(restrict, 2, 4, 1.0, INSERT_VALUES); CHKERRQ(ierr);
>     ierr = MatAssemblyBegin(restrict, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>     ierr = MatAssemblyEnd(restrict, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
>     ierr = MatView(restrict, PETSC_VIEWER_STDOUT_SELF);
>     {    // Solving the linear problem Id*x = 0 works
>         KSP ksp;
>         ierr = KSPCreate(PETSC_COMM_SELF, &ksp); CHKERRQ(ierr);
>         ierr = KSPSetType(ksp, KSPFGMRES); CHKERRQ(ierr);
>         ierr = KSPSetOperators(ksp, Id, Id, SAME_PRECONDITIONER);
> CHKERRQ(ierr);
>         PC pc;
>         ierr = KSPGetPC(ksp, &pc); CHKERRQ(ierr);
>         ierr = PCSetType(pc, PCMG); CHKERRQ(ierr);
>         ierr = PCMGSetLevels(pc, 2, 0); CHKERRQ(ierr);
>         ierr = PCMGSetGalerkin(pc, PETSC_TRUE); CHKERRQ(ierr);
>         ierr = PCMGSetInterpolation(pc, 1, interp); CHKERRQ(ierr);
>         ierr = PCMGSetRestriction(pc, 1, restrict); CHKERRQ(ierr);
>         ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
>         Vec b; // Trivial RHS for the linear problem
>         ierr = VecDuplicate(x, &b); CHKERRQ(ierr);
>         ierr = VecSet(b, 0); CHKERRQ(ierr);
>         ierr = KSPSolve(ksp, b, x); CHKERRQ(ierr);
>         ierr = VecView(x, PETSC_VIEWER_STDOUT_SELF);
>         ierr = VecDestroy(&b); CHKERRQ(ierr);
>         ierr = KSPDestroy(&ksp); CHKERRQ(ierr);
>         ierr = PetscPrintf(PETSC_COMM_SELF, "KSPSolve worked\n");
> CHKERRQ(ierr);
>     {    // This block of code causes a segfault
>         TS ts;
>         ierr = TSCreate(PETSC_COMM_SELF, &ts); CHKERRQ(ierr);
>         ierr = TSSetProblemType(ts, TS_LINEAR); CHKERRQ(ierr);
>         ierr = TSSetType(ts, TSBEULER); // Use an implicit scheme
>         ierr = TSSetInitialTimeStep(ts, 0.0, 0.1); CHKERRQ(ierr);
>         ierr = TSSetSolution(ts, x); CHKERRQ(ierr);
>         ierr = TSSetRHSFunction(ts, 0, TSComputeRHSFunctionLinear, 0);
> CHKERRQ(ierr);
>         ierr = TSSetRHSJacobian(ts, Id, Id,
> TSComputeRHSJacobianConstant, 0); CHKERRQ(ierr);
>         ierr = TSSetIFunction(ts, 0, TSComputeIFunctionLinear, 0);
> CHKERRQ(ierr);
>         ierr = TSSetIJacobian(ts, Id, Id, TSComputeIJacobianConstant, 0);
>         KSP ksp;
>         ierr = TSGetKSP(ts, &ksp); CHKERRQ(ierr);
>         PC pc;
>         ierr = TSSetUp(ts); CHKERRQ(ierr);
>         ierr = TSStep(ts); CHKERRQ(ierr);
>         ierr = TSDestroy(&ts); CHKERRQ(ierr);
>     ierr = MatDestroy(&restrict); CHKERRQ(ierr);
>     ierr = MatDestroy(&interp); CHKERRQ(ierr);
>     ierr = VecDestroy(&x); CHKERRQ(ierr);
>     ierr = MatDestroy(&Id); CHKERRQ(ierr);
>     ierr = PetscFinalize(); CHKERRQ(ierr);
>     return 0;
> The actual output of the program when running without a debugger is:
> Matrix Object: 1 MPI processes
>   type: seqaij
> row 0: (0, 1)
> row 1: (1, 1)
> row 2: (2, 1)
> row 3: (3, 1)
> row 4: (4, 1)
>   type: seqaij
> row 0: (0, 1)
> row 1: (0, 0.5)  (1, 0.5)
> row 2: (1, 1)
> row 3: (1, 0.5)  (2, 0.5)
> row 4: (2, 1)
>   type: seqaij
> row 0: (0, 1)
> row 1: (2, 1)
> row 2: (4, 1)
> Vector Object: 1 MPI processes
>   type: seq
> 0
> 0
> 0
> 0
> 0
> KSPSolve worked
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
> ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
> find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] DMCoarsen line 1809 src/dm/interface/dm.c
> [0]PETSC ERROR: [0] PCSetUp_MG line 546 src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: [0] PCSetUp line 868 src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 192 src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPSolve line 356 src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] SNESSolve_KSPONLY line 14
> src/snes/impls/ksponly/ksponly.c
> [0]PETSC ERROR: [0] SNESSolve line 3589 src/snes/interface/snes.c
> [0]PETSC ERROR: [0] TSStep_Theta line 162
> src/ts/impls/implicit/theta/theta.c
> [0]PETSC ERROR: [0] TSStep line 2499 src/ts/interface/ts.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./testcase.elf on a linux-gnu-c-debug named lenovo by
> tmac Sat Dec 14 14:35:56 2013
> [0]PETSC ERROR: Libraries linked from
> /tmp/petsc-3.4.3/linux-gnu-c-debug/lib
> [0]PETSC ERROR: Configure run at Fri Nov 22 11:07:41 2013
> [0]PETSC ERROR: Configure options --with-shared-libraries
> --with-debugging=1 --useThreads 0 --with-clanguage=C++ --with-c-support
> --with-fortran-interfaces=1 --with-scalar-type=complex
> --with-mpi-dir=/usr/lib/openmpi --with-blas-lib=-lblas
> --with-lapack-lib=-llapack --with-blacs=1
> --with-blacs-include=/usr/include
> --with-blacs-lib="[/usr/lib/libblacsCinit-openmpi.so,/usr/lib/libblacs-openmpi.so]"
> --with-scalapack=1 --with-scalapack-include=/usr/include
> --with-scalapack-lib=/usr/lib/libscalapack-openmpi.so --with-mumps=1
> --with-mumps-include=/usr/include
> --with-mumps-lib="[/usr/lib/libdmumps.so,/usr/lib/libzmumps.so,/usr/lib/libsmumps.so,/usr/lib/libcmumps.so,/usr/lib/libmumps_common.so,/usr/lib/libpord.so]"
> --with-umfpack=1 --with-umfpack-include=/usr/include/suitesparse
> --with-umfpack-lib="[/usr/lib/libumfpack.so,/usr/lib/libamd.so]"
> --with-cholmod=1 --with-cholmod-include=/usr/include/suitesparse
> --with-cholmod-lib=/usr/lib/libcholmod.so --with-spooles=1
> --with-spooles-include=/usr/include/spooles
> --with-spooles-lib=/usr/lib/libspooles.so --with-ptscotch=1
> --with-ptscotch-include=/usr/include/scotch
> --with-ptscotch-lib="[/usr/lib/libptesmumps.so,/usr/lib/libptscotch.so,/usr/lib/libptscotcherr.so]"
> --with-fftw=1 --with-fftw-include=/usr/include
> --with-fftw-lib="[/usr/lib/x86_64-linux-gnu/libfftw3.so,/usr/lib/x86_64-linux-gnu/libfftw3_mpi.so]"
> --with-superlu=1 --with-superlu-include=/usr/include/superlu
> --with-superlu-lib=/usr/lib/libsuperlu.so
> --CXX_LINKER_FLAGS=-Wl,--no-as-needed
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> Best regards
> Torquil Sørensen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131218/5f2aa212/attachment.html>
