[petsc-users] Fwd: Questions using PCFIELDSPLIT
Adriano Côrtes adrimacortes at gmail.com
Sat Dec 14 14:00:11 CST 2013
2013/12/14 Jed Brown <jedbrown at mcs.anl.gov>
> Adriano Côrtes <adrimacortes at gmail.com> writes:
> > 2013/12/14 Jed Brown <jedbrown at mcs.anl.gov>:
> >> Use -ksp_view to check that these are being used.  I recommend setting
> >> all these options using run-time options unless your code is taking
> >> active control over the choice of algorithm.
> > Actually it is being done. Check the -snes_view bellow
> >  0 SNES Function norm 9.644918978350e-02
> >     0 KSP Residual norm 1.297271248442e-01
> >   1 SNES Function norm 9.644918978350e-02
> > Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 1
> > SNES Object: 1 MPI processes
> >   type: ksponly
> >   maximum iterations=50, maximum function evaluations=10000
> >   tolerances: relative=1e-05, absolute=1e-50, solution=1e-08
> >   total number of linear solver iterations=1
> >   total number of function evaluations=2
> >   SNESLineSearch Object:   1 MPI processes
> >     type: basic
> >     maxstep=1.000000e+08, minlambda=1.000000e-12
> >     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> > lambda=1.000000e-08
> >     maximum iterations=1
> >   KSP Object:   1 MPI processes
> >     type: minres
> >     maximum iterations=10000, initial guess is zero
> >     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
> >     left preconditioning
> >     using PRECONDITIONED norm type for convergence test
> >   PC Object:   1 MPI processes
> >     type: fieldsplit
> >       FieldSplit with Schur preconditioner, factorization DIAG
> >       Preconditioner for the Schur complement formed from user provided matrix
> >       Split info:
> >       Split number 0 Defined by IS
> >       Split number 1 Defined by IS
> >       KSP solver for A00 block
> >         KSP Object:        (fieldsplit_u_)         1 MPI processes
> >           type: cg
> >         PC Object:        (fieldsplit_u_)         1 MPI processes
> >           type: jacobi
> >           linear system matrix = precond matrix:
> >           Matrix Object:           1 MPI processes
> >             type: seqaij
> >             rows=220, cols=220
> >             total: nonzeros=11552, allocated nonzeros=11552
> >             total number of mallocs used during MatSetValues calls =0
> >               not using I-node routines
> >       KSP solver for S = A11 - A10 inv(A00) A01
> >         KSP Object:        (fieldsplit_p_)         1 MPI processes
> >           type: cg
> >         PC Object:        (fieldsplit_p_)         1 MPI processes
> >           type: jacobi
> >           linear system matrix followed by preconditioner matrix:
> >             type: schurcomplement
> See that "fieldsplit_p_" uses a MATSCHURCOMPLEMENT and actually iterates
> on that reduced system.  This is different from what is typically done
> in full-space iterative methods.
Dear Jed,
Can you elaborate more this comment? What is a MATSCHURCOMPLEMENT
object? You mean that S is built? Or is it matrix-free as you said
bellow?
> >             rows=100, cols=100
> >               Schur complement A11 - A10 inv(A00) A01
> >               A11
> >                   type: seqaij
> >                   rows=100, cols=100
> >                   total: nonzeros=1936, allocated nonzeros=1936
> >               A10
> >                   type: seqaij
> >                   rows=100, cols=220
> >                   total: nonzeros=4752, allocated nonzeros=4752
> >               KSP of A00
> >     1 MPI processes
> >                   type: cg
> >    1 MPI processes
> >                   type: jacobi
> >                     type: seqaij
> >                     rows=220, cols=220
> >               A01
> >                   type: seqaij
> >                   rows=220, cols=100
> >             type: seqaij
> >             rows=100, cols=100
> >       type: seqaij
> >       rows=320, cols=320
> >       total: nonzeros=22992, allocated nonzeros=24996
> >       total number of mallocs used during MatSetValues calls =1156
> > L2 errors: u=0.0132378 p=0.0593741
> >>>   where I'm providing the pressure mass matrix as a preconditioner for S.
> >> Where are you putting it?
> > I'm calling a callback function to compute Q (pressure mass matrix) and calling
> > ierr = PCFieldSplitSchurPrecondition(pc,schurpre,Q);CHKERRQ(ierr);
> > where schurpre = PC_FIELDSPLIT_SCHUR_PRE_USER;
> >>> When I run with
> >>> -snes_type ksponly
> >>> -ksp_type minres
> >>> -pc_type fieldsplit
> >>>  #Velocity
> >>> -fieldsplit_u_ksp_type cg
> >>> -fieldsplit_u_pc_type jacobi
> >>> -fieldsplit_u_ksp_rtol 1e-05
> >>> -fieldsplit_u_ksp_monitor
> >>> #Pressure
> >>> -fieldsplit_p_ksp_type cg
> >>> -fieldsplit_p_pc_type jacobi
> >>> -fieldsplit_p_ksp_rtol 1e-05
> >>> -fieldsplit_p_ksp_monitor
> >>> the solution does not converge
> >> "does not converge" is to imprecise to say anything.  What exactly do
> >> you observe?
> > Since it's an analytical solution I'm computing the L2 Norm. When I
> > run with -ksp_type minres I get
> Use -ksp_converged_reason to find out why the linear solve above did not
> converge.  Maybe due to an indefinite preconditioner?
This was there result of -ksp_converged_reason
  Linear solve did not converge due to DIVERGED_INDEFINITE_MAT iterations 1
This I didn't understand, because minres is supposed to work for
symmetric indefinite matrices. Isn't it? What am I missing here?
> > and when I run with -ksp_type gmres I get
> >     1 KSP Residual norm 1.269027428700e-01
> >     2 KSP Residual norm 1.177913273071e-01
> >     3 KSP Residual norm 4.746342719564e-05
> >     4 KSP Residual norm 4.242617241067e-05
> >     5 KSP Residual norm 9.541981683274e-07
> >   1 SNES Function norm 1.468436883950e-06
> > Nonlinear solve converged due to CONVERGED_ITS iterations 1
> > L2 errors: u=4.097e-05 p=8.95462e-05
> >>> (i'm testing an analytical one), but when I use -ksp_type gmres it
> >>> converges.
> >> Are you sure your matrices are symmetric?  (Including boundary conditions.)
> > It supposed to be, but now that you asked I will check it, because
> > this can be why minres isn't working for me.
> Yes that or if the preconditioner is not SPD.  That could be as simple
> as getting the sign wrong in a preconditioning matrix.
> >>> If you guys want I can dump both monitors outputs on a file an attach
> >>> on the email.
> >>> My second question is: what options I have to set up if I want to use as
> >>> preconditionr for M the matrix
> >>>         [  A    0  ]
> >>> P =   [            ]
> >>>         [  0    Q  ]
> >>> where again Q is the pressure mass matrix, and with A and Q being solved by
> >>> CG with BJACOBI.
> >> I can't tell for sure from what you've sent, but PCFIELDSPLIT is likely
> >> iterating on the actual Schur complement S = - B A^{-1} B^T,
> >> preconditioned by your matrix Q.
> > I guess I did not make myself clear. It was supposed to be a new
> > question, that is, what I'm doing now is what you said above, but
> > since I'm using an inf-sup stable discretization Q and S are spectral
> > equivalent, what I'd like to do after is to precondition the Stokes
> > system with A and Q, that is using ksp(A) and ksp(Q) to apply the
> > block-diagonal preconditioner.
> If you want to use an iterative method for Q, you can skip over the
> matrix-free Schur complement operator by using something like
> -fieldsplit_p_ksp_type preonly -fieldsplit_p_pc_type ksp, though usually
> one V-cycle is enough and keep the iteration linear regardless of
> tolerances.  You might look at the src/ksp/ksp/examples/tutorials/ex42.c
> runs (see the makefile or ex42*.opts) for examples of solving similar
> systems.
I will take a look. Thanks. But just to know if I set
-fieldsplit_p_ksp_type preonly -fieldsplit_p_pc_type ksp, how do I
choose the ksp? Multigrid V-cycle as you said is the default in this
case?
Thank you.
Adriano
