[petsc-users] Fwd: Questions using PCFIELDSPLIT
Adriano Côrtes adrimacortes at gmail.com
Sat Dec 14 13:08:50 CST 2013
2013/12/14 Jed Brown <jedbrown at mcs.anl.gov>:
> Adriano Côrtes <adrimacortes at gmail.com> writes:
>> Hi all,
>> I'm trying to play with PCFIELDSPLIT, but after reading I'm still confused
>> interpreting the monitors. I'm trying to solve a Stokes problem
>>         [  A    B^t  ]
>> M =  [               ]
>>         [  B    0     ]
>> My first question is about the MINRES behaviour with pcfieldsplit. My
>> options for pcfieldsplit are
>>     ierr = PCFieldSplitSetType(pc,PC_COMPOSITE_SCHUR);CHKERRQ(ierr);
>>     PCFieldSplitSchurFactType schurfact = PC_FIELDSPLIT_SCHUR_FACT_DIAG;
>>     ierr = PCFieldSplitSetSchurFactType(pc,schurfact);CHKERRQ(ierr);
>>     PCFieldSplitSchurPreType  schurpre = PC_FIELDSPLIT_SCHUR_PRE_USER;
> Use -ksp_view to check that these are being used.  I recommend setting
> all these options using run-time options unless your code is taking
> active control over the choice of algorithm.
Actually it is being done. Check the -snes_view bellow
 0 SNES Function norm 9.644918978350e-02
    0 KSP Residual norm 1.297271248442e-01
  1 SNES Function norm 9.644918978350e-02
Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 1
SNES Object: 1 MPI processes
  type: ksponly
  maximum iterations=50, maximum function evaluations=10000
  tolerances: relative=1e-05, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=1
  total number of function evaluations=2
  SNESLineSearch Object:   1 MPI processes
    type: basic
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=1
  KSP Object:   1 MPI processes
    type: minres
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object:   1 MPI processes
    type: fieldsplit
      FieldSplit with Schur preconditioner, factorization DIAG
      Preconditioner for the Schur complement formed from user provided matrix
      Split info:
      Split number 0 Defined by IS
      Split number 1 Defined by IS
      KSP solver for A00 block
        KSP Object:        (fieldsplit_u_)         1 MPI processes
          type: cg
        PC Object:        (fieldsplit_u_)         1 MPI processes
          type: jacobi
          linear system matrix = precond matrix:
          Matrix Object:           1 MPI processes
            type: seqaij
            rows=220, cols=220
            total: nonzeros=11552, allocated nonzeros=11552
            total number of mallocs used during MatSetValues calls =0
              not using I-node routines
      KSP solver for S = A11 - A10 inv(A00) A01
        KSP Object:        (fieldsplit_p_)         1 MPI processes
          type: cg
        PC Object:        (fieldsplit_p_)         1 MPI processes
          type: jacobi
          linear system matrix followed by preconditioner matrix:
            type: schurcomplement
            rows=100, cols=100
              Schur complement A11 - A10 inv(A00) A01
              A11
                  type: seqaij
                  rows=100, cols=100
                  total: nonzeros=1936, allocated nonzeros=1936
              A10
                  type: seqaij
                  rows=100, cols=220
                  total: nonzeros=4752, allocated nonzeros=4752
              KSP of A00
    1 MPI processes
                  type: cg
   1 MPI processes
                  type: jacobi
                    type: seqaij
                    rows=220, cols=220
              A01
                  type: seqaij
                  rows=220, cols=100
            type: seqaij
            rows=100, cols=100
      type: seqaij
      rows=320, cols=320
      total: nonzeros=22992, allocated nonzeros=24996
      total number of mallocs used during MatSetValues calls =1156
L2 errors: u=0.0132378 p=0.0593741
>>   where I'm providing the pressure mass matrix as a preconditioner for S.
> Where are you putting it?
I'm calling a callback function to compute Q (pressure mass matrix) and calling
ierr = PCFieldSplitSchurPrecondition(pc,schurpre,Q);CHKERRQ(ierr);
where schurpre = PC_FIELDSPLIT_SCHUR_PRE_USER;
>> When I run with
>> -snes_type ksponly
>> -ksp_type minres
>> -pc_type fieldsplit
>>  #Velocity
>> -fieldsplit_u_ksp_type cg
>> -fieldsplit_u_pc_type jacobi
>> -fieldsplit_u_ksp_rtol 1e-05
>> -fieldsplit_u_ksp_monitor
>> #Pressure
>> -fieldsplit_p_ksp_type cg
>> -fieldsplit_p_pc_type jacobi
>> -fieldsplit_p_ksp_rtol 1e-05
>> -fieldsplit_p_ksp_monitor
>> the solution does not converge
> "does not converge" is to imprecise to say anything.  What exactly do
> you observe?
Since it's an analytical solution I'm computing the L2 Norm. When I
run with -ksp_type minres I get
and when I run with -ksp_type gmres I get
    1 KSP Residual norm 1.269027428700e-01
    2 KSP Residual norm 1.177913273071e-01
    3 KSP Residual norm 4.746342719564e-05
    4 KSP Residual norm 4.242617241067e-05
    5 KSP Residual norm 9.541981683274e-07
  1 SNES Function norm 1.468436883950e-06
Nonlinear solve converged due to CONVERGED_ITS iterations 1
L2 errors: u=4.097e-05 p=8.95462e-05
>> (i'm testing an analytical one), but when I use -ksp_type gmres it
>> converges.
> Are you sure your matrices are symmetric?  (Including boundary conditions.)
It supposed to be, but now that you asked I will check it, because
this can be why minres isn't working for me.
>> If you guys want I can dump both monitors outputs on a file an attach
>> on the email.
>> My second question is: what options I have to set up if I want to use as
>> preconditionr for M the matrix
>>         [  A    0  ]
>> P =   [            ]
>>         [  0    Q  ]
>> where again Q is the pressure mass matrix, and with A and Q being solved by
>> CG with BJACOBI.
> I can't tell for sure from what you've sent, but PCFIELDSPLIT is likely
> iterating on the actual Schur complement S = - B A^{-1} B^T,
> preconditioned by your matrix Q.
I guess I did not make myself clear. It was supposed to be a new
question, that is, what I'm doing now is what you said above, but
since I'm using an inf-sup stable discretization Q and S are spectral
equivalent, what I'd like to do after is to precondition the Stokes
system with A and Q, that is using ksp(A) and ksp(Q) to apply the
block-diagonal preconditioner.
Adriano.
