[petsc-users] Stiff ODEs
Katy Ghantous katyghantous at gmail.com
Thu Dec 5 11:41:03 CST 2013
thanks! yep, it works.. but only after i removed the folder and cloned all
over again before configure and make.
it might have messed up because i had to install opengl after installing
petsc.. and so had to do the configuration again to take it into account..
(but i did that the second time around without specifying petsc scalar,
while i specified it as complex before..) but that is just a speculation.
thanks for the help!
On Thu, Dec 5, 2013 at 5:03 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > This makes no sense. The makefiles appear correct, and the gmres makefile
> > has the dgmres
> > directory, but no record of it building in that directory is in the
> > makefile.
> > Jed, how could #requiresscalar be failing?
> Katy, please send linux-gnu-cxx-debug/conf/petscvariables.  It should
> contain the line
>   PETSC_SCALAR = real
> Could you try reconfiguring, and if the problem persists, send
> configure.log?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131205/3a7e5b75/attachment-0001.html>
