[petsc-users] question about PetscLogEvents
Wed Dec 4 22:28:27 CST 2013
Mohammad Mirzadeh <mirzadeh at gmail.com> writes:
> I'm gathering statistics for scaling analysis of my code and I'm making use
> of PetscLogEvent objects. Some of events I'm trying to log have run-times
> of few (1-5) seconds. Should I worry about any additional overheads?
> In general how long should an event be to not worry about overheads?
When you run with -log_summary, you'll see a line like this:
  Average time to get PetscTime(): 9.53674e-08
This value of around 100 nanoseconds is typical, and is about the same
as a full cache miss.  You generally want your events to take
significantly longer than this, say at least a microsecond.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131204/83d360cc/attachment.pgp>
