[petsc-users] Performance of PETSc TS solver
Fri Aug 30 19:19:16 CDT 2013
"Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> I don’t know. TSARKIMEX doesn’t work for me either.
> “TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase
> -ts_max_snes_failures or make negative to attempt recovery!”
It uses adaptive time stepping and the large time step cases might not
converge, and thus have to shorten the step.  Try using
-ts_max_snes_failures 20 -ts_adapt_monitor to see what's going on.  You
could start with -ts_arkimex_type 1bee (backward Euler with
extrapolation-based error estimator) before trying the higher order
schemes.
> Am I use it wrong?
> I simply replaced:
> “  ierr = TSCreate(PETSC_COMM_WORLD, &ts); CHKERRQ(ierr);
>   ierr = TSSetType(ts, TSTHETA); CHKERRQ(ierr);
>   ierr = TSThetaSetTheta(ts, 0.5); CHKERRQ(ierr);”
> by:
>   TSCreate(PETSC_COMM_WORLD,&ts);
>   //TSSetType(ts,TSROSW);
>   TSSetType(ts,TSARKIMEX);
Suggest just calling TSSetFromOptions and then pass -ts_type arkimex at run-time.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130830/4666ea7a/attachment.pgp>
